85kwh battery 250 rated at 100%. 74.1kwh remaining. 221 max CAC.
How many miles? Your getting a new battery pack instead of a new main contactor?
I don’t know yet.How many miles? Your getting a new battery pack instead of a new main contactor?
They are replaceable. Something must have gone haywire during the installation?For all I know, the contactor and the battery are closely integrated as a pack (contactor is part of the pack), you just can't replace the contactor without replacing the pack (once you get a new pack, you get a new contactor in it).
Don't know if it's still true for the newer cars though.
They have a fix for this now. I have an appointment this monday 9/16 to get it fix. They are using some UV machine so let's hope it works for the long haul and just a quick fix. Call your service center.
2019.20.1 - 11. JuneI believe it was 2019.24.x mid-July
Mine started the download via wifi earlier this week then stopped within a minute or two. Now it no longer says an update is available. Now that I am paying attention I noticed in the last week mine has stopped charging at 229/230 miles at 90% on the app then without more charging I will go to leave in the morning and it will say I have 232 miles. It's like the opposite of vampire drain and doesn't make sense to me. I don't recall it doing this before.Anyone installed the newest software after 2019.32.1? What’s the new updates and did it help with battery or suckgate ?
Great video. Thanks for posting!This video (at the tagged point) shows the contactor removal and what's inside. I found it interesting:
Mike
I've had contactors replaced after the balloon noise escalated to limited power (worse than the volt cap, I had 100kW max). Still have original battery.For all I know, the contactor and the battery are closely integrated as a pack (contactor is part of the pack), you just can't replace the contactor without replacing the pack (once you get a new pack, you get a new contactor in it).
I just installed this morning.Anyone installed the newest software after 2019.32.1? What’s the new updates and did it help with battery or suckgate ?
The contactors can be replaced in all of the packs. Most older Model Ss have had the contactors replaced at least once.
Thanks for correcting me. I did write "For all I know" at the beginning of my sentence, supposed to make it speculative, I was told recently
BTW, after the drive drivetrain replacement, the milling noise of course disappeared along with the clicking sound. However, the clicking sound is now back, noticeable whenever I press on the accelerator at the low speed, especially from stop. Hopefully it's not the drivetrain going bad again.
And I didn't rate your post disagree because you made it clear you weren't sure. (But I thought you might like to know that they are indeed replaceable.)
I think the clicking sound often comes from the axel splines where they go into the hubs. I have seen where people report that Tesla greases the splines and/or just tightens the axel nuts to resolve the issue. So you might want to try having the axel nuts tightened to see if that helps. (I think the correct procedure is to loosen them and then re-torque them.)
Also, thanks for the tip on the clicking sound. I'm in the extended warranty period now and, if this needs to be taken care of sooner to avoid causing more problems, looks like this is not something a mobile service can do as the car needs to be on the lift?
