The tech is still conferring with the service team on if they can do anything differently than only installing software to "fix" the issue. He said that I can retrieve the car and drive it like it is with the battery alert.
If I can get him to unstage 19.40 then I will choose that path for now. I realized there's additional logging I probably want to get like max current at 15 20 and 25%. Currently(no pun intended) it will pull the full 1516 amps at 30%.
I also want to run it down to empty which I've never done before and measure the module voltages. I want to see when it dies if it's even close to empty or if dies at say 10% because 58 can't keep up. If it dies at 10%, then the only way you can mask this with software is making 10% the displayed 0% i.e. capping on the bottom.
I understand now why they cap the top. If you have a module with dead cells, then the remaining cells will get overcharged as compared to the rest of the modules which will accelerate degradation.
I strongly suspect those that are capped aren't capped at just maximum voltage but also at minimum voltage. It would be really asesome if someone who is not effected and doesn't have a bad module could run their car to empty and take a CANBUS snapshot of the module voltages.
Also, if they're not going to void the warranty, at some point module 58 will be beyond even v10s ability to mask and then I can try again. It will probably be when I break down on the side of the road.
