I've read the accusations, I just don't see any proof. There are plenty of complaints at the Tesla forums, it would be very strange for Tesla to remove specific complaint threads and not others. I've been involved with that forum long enough to know that Tesla does not remove posts. If they did, why did the post you linked above remain? Makes no sense.
I don't believe everything I read, especially when there is no evidence to support
Yes.I posted this:
Range and acceleration loss | Tesla
And it’s still up, but doesn’t have any replies.
Can you see it?
Agreed I just thought maybe someone heard additional comments.That's part of the problem. The will not even conform WHY let alone IF they will give the range back.
Yes. I just posted to it and put in a link to here. We will see if it remains.I posted this:
Can you see it?
@egn1 I have to say that Tesla is at fault for not communicating as you say. But the cause of the fires in the 85kWh batteries is real, as we saw in Hong Kong and Singapore. They are being responsible by releasing a BMS software update to prevent future fires. But for heaven's sake, they need to tell the owners what's going on. We all have our set of stories how unannounced range reduction effected us, reduced car value and ticked us off. But that is the issue. We all know how to charge our cars and manage the batteries. That is why this flies in the face of you, me and the other Tesla owners here that Tesla would throw range reduction back on us. To lose 15-20% overnight with a software update has no reflection on how an owner cares for their Tesla's battery. Further insult is their comment to "Roadshow" that "most" owners won't notice it. WHO'S IN FOR THE CLASS ACTION!!??Tesla is not at fault regarding making the real degradation visible here, but it is certainly at fault regarding the missing communication. If only a few owners are hit very hard, by losing more than 10 % of there range, then it should be also possible to replace the batteries by refurbished ones. The parameters should be transparent.
I don't believe everything I read, especially when there is no evidence to support.
Also weird that there are no threads about this at official Tesla Forums. Could Tesla be removing threads relating to this issue? Seems strange nobody over there is discussing it.
Hi,
I also own a S85 with about 75.000 miles, but it lost only about 5 miles after the update, so far.
I think degradation of the battery wasn't defined very well, so far.
We all thought that the current amount of energy available at full charge of 4,2 V divided by the amount of energy of a new battery charged to 4,2 V subtracted from 1 and multiplied by 100 will be the degradation in percent. In pure physical terms this may be true, but technically this doesn't take the internal chemical changes in the battery into account, that have influence on usability (internal resistance) and safety (lithium plating). Up to the firmware update, causing a drastically lower range being displayed, it seems to be that Tesla, when calculating the state-of-health of the battery in form of the capacity for full charge, didn't take the usability and safety much into account. So over time the lithium plating of the cells, caused by high charge power at high SOC and low battery temperature, is increasing more and more, until the separator is punctured, causing internal shorts and my finally cause battery fire. That this happened only a few times up to now, even there are billions of cells in use, is a wonder. This shows that Tesla has done a good job in improving the BMS over time. The last changes definitely go into the same direction.
As has been already written, Tesla may now detect the health of the battery regarding safety better, by detecting the lithium plating through differential voltage analysis, when charging to 100 %. If the voltage starts to rise with a higher slope than normal, charging is stopped. The reason for this sharp rise is that the lithium ions cannot be intercalated into the graphite anode fast enough, which finally increase lithium plating further.
So I agree with those that say that the degradation (capacity, usability and safety) was already there. We just didn't see it until Tesla introduced the new software. In my opinion Tesla is not at fault regarding making the real degradation visible here, but it is certainly at fault regarding the missing communication. If only a few owners are hit very hard, by losing more than 10 % of there range, then it should be also possible to replace the batteries by refurbished ones. The parameters should be transparent.
Taking this into account, I can only warn people to constantly test the battery capacity with 100 % charges. They may make the situation even worse, because nobody knows if Tesla is already stopping charging early enough to prevent further lithium plating. It is better to use either ScanMyTesla or TM-Spy to read out the BMS values, but charging to lower SOC and dividing the displayed range by the SOC percentage, will also be good enough.
How can the risk of lithium plating reduced?
Charging in summer with warm battery is not that much of a problem. Just charge immediately before a road trip to the SOC that is required.
- Don't charge to high SOC
- Don't charge when battery is cold
- Don't charge with range mode on when battery is cold
In winter it is better to charge immediately after the trip, when the battery is still warm. But avoid charging to more than 80 % if possible.
Keeping the car at SOC of 10 - 20 % most of the time, gives the chance to reverse lithium plating a bit.
BTW, I don't see the loss of capacity and the lower charge rates at the SuC as separate issues. Both work together in reducing the chance of lithium plating. So at least all owners of vehicles with S85 cell type may have to live with more visible degradation and lower charge rates.
Finally, I think this problem will not be that visible with cells with silicon in the anode, because there can the lithium ions be intercalated more easily.
I hope this helps,
Emil
Yes. I think if we stick to kWh capacity it is a cleaner discussion. Anytime "miles" or "percentage" come up as a measurement metric, it is subject to additional formulas and calculations. I bought a car with 77 kWh and now have a battery with 60 kWh. It was about 73 kWh before 2019.16.2. Plain and simple.From what I read in your post, you believe the real degradation rate has always been much higher than what the crowd-source data has shown for years because that data has been based on a misleading BMS reporting, showing the degradation much lower than what has been for the older cars; and that the new BMS reporting is more aligned with the real degradation rate.
Degradation visible in the crowd sourced data took only account the range calculated from the calculated full range by the BMS at the time of reading. The BMS algorithm has changed slightly from time to time.
But even then the crowd sourced data showed a lower degradation than the reading from ScanMyTesla. I once discussed this with Matteo, who managed the data, but we didn't come to an agreement.
I am also wondering why only the plotted average was in discussion, may be because it looked so good and everybody wanted only to see to positives in the chart. But there are also a lot negatives in there by having a lot of data point below the average curve. For me this either means that the production process for cells has a very large deviation, or the usage has a high influence, or both.
It would be great if Tesla owners could continue to update the writable copy of the MaxRange Tesla Battery Survey again. This would help to see the further trend of degradation.
As mentioned above it should be avoided to charge to 100 % for determining the range. Best to use ScanMyTesla or calculation from lower SOC.
The problem with using kWh capacity is NOT plain OR simple. Tesla does not display kWh capacity anyywhere visible to the owners. The "77kWh usable" of a new 85 kWh pack was not known without reading the CANBUS.Yes. I think if we stick to kWh capacity it is a cleaner discussion. Anytime "miles" or "percentage" come up as a measurement metric, it is subject to additional formulas and calculations. I bought a car with 77 kWh and now have a battery with 60 kWh. It was about 73 kWh before 2019.16.2. Plain and simple.
Thanks for the additionals. You said @75k miles you have lost only about 5 miles after the update. What's your estimated full range at this time and the charging recipe you use?
Emil
