AMPd
This would also be a great location for solar, although the palm trees might be in the way a bit.
If they were to install a solar canopy, it can be pretty big!
Thanks for the heads-up! How hot is it down there these days? Heat could be a contributing factor to power limitations.
And did you have a chance to try unshared stalls? (e.g. 1A while 1B was unused)?
Absolutely. I'm a fanatic about that sort of thing. I tried two separate unpaired stalls at Harris and both delivered reduced power after initially showing > 100 kW.
I can see that there a currently some charging reduced flags set for several posts at Harris Ranch. Most affected are posts 2AB and 3B, with some minor issues flagged for 1AB, 3B, 4AB, 6B and 7A. Not all owners plugging in will experience issues charging, especially on those flagged with only minor issues reported.
Tesla said this about a week ago:
In my experience, 5AB is indeed golden and sometimes even splitting 5AB with someone else is a net win over the other stalls.
It hasn't been 100% consistent for me. I had good luck at 3A splitting with 3B, but I also experienced 7A dropping me down to 50kW minutes after starting to charge normally.
Teslas effort to acquire SolarCity has nothing to do with some Superchargers in California not consistently delivering full power.Tesla should be more focused on dealing with issues like this than aquiring solarcity if it wasn't to be successful.
Did you call tesla to report the issue?I appreciate the heads-up about chargers 5AB at Harris Ranch.
At 9AM 10/13 we pulled into 5A even though 5B was occupied. Charge rate was ~72kW, so moved to unpaired 4B, which started up at 105kW so we went inside for breakfast. After ordering I went back out to check and the charge rate had dropped to 62kW . As I got back to the front door, I saw people getting into the X at 5B so I went back and moved to 5A. 5A was just fine, starting at 110kW with gradual tapering, so when we were done with breakfast after an hour the car was at 245 rated miles and ready to go. We also noted that the slowed down 4B cable was hot to the touch when I moved the car after 10 minutes, much more so than the 5A cable after nearly an hour of charging.
At 4PM 10/16 the 5's were unpaired, we plugged into 5A again and had a full charge after an hour and a half of dinner and shopping.
