In my 85 (produced Oct 27 2015) there were no 12V jumpstart contacts behind the bumper anymore, they are located in the frunk under the windscreeen wipers under that plastic cover.
The thing with the parking sensors really is an issue.
In the manual it says that two of the sensors are by mistake wrongly indicated on the FBR. That is not really an issue.
It's more of an issue that two other locations are not correct either. And the manual says nothing about this.
I drilled the two lower holes as indicated on the bumper. And I found out that they are not in the same distance from the middle of the bumper. In Europe a front number plate is obligatory and when the bumper was installed, it became clear that one hole is 2-3 cm away from the spot it should be. Without a number plate, one will not see this, but with a number plat, it becomes obvious. So after mounting the numberplate, I decided to move that to the right, to get it in the middle of the two holes.
Furthermore: the bumper is thicker than the original prefacelift bumper. So the sensors are not flat with the bumper outside as with the original one.
So I am not satisfied about this at all.
For a bumper that is 5 times the price of an original one, this should not happen! Shipment was a problem too. The bumper was shipped to the wrong airport, despite the confirmation of the vendor T-Sportline, which cost me another USD 200 extra to get it home..
So I do not recommend buying this aftermarket bumper.
