Hahaha I don’t understand the fog lights fetish. I forgot my car even had them and I certainly have never used them even though I have driven in fog at least twice in the last 6 years of ownership. No floor mats is annoying and although common in the car world I wish Tesla was above this.
No, Tesla are purely using the obsolete & inapplicable NEDC testing, to justify them being sold for the same price. The 20” wheels do reduce range, howeverBut Tesla sales still tell me I must choose range (LR AWD) or acceleration (P3D). It is possible Tesla are software limiting range on P3D in AU. The fact the P3D+ and P3D- are quoted as the same range 560kms is suspicious since 20" wheels should reduce range, but lowered suspension might compensate to a certain extent.
The only way to know for sure is to check the wheel weight of each size, as well as the rolling resistance. If tesla have made the same weight to both sizes than the range difference will likely not be measurable, pending tyre type.No, Tesla are purely using the obsolete & inapplicable NEDC testing, to justify them being sold for the same price. The 20” wheels do reduce range, however
At this point I think I'd be willing to pop round to antarctica to pick up my car.
Plus the southern tip of the southern most continent doesn’t exist unless you are a flat earth believerWaste of time, you'll only get an ICE vehicle!
18s are aeros though which gives a 5-10% increase in range from what i've read.The only way to know for sure is to check the wheel weight of each size, as well as the rolling resistance. If tesla have made the same weight to both sizes than the range difference will likely not be measurable, pending tyre type.
I’ll do a little test next week when I’m back in aust. Have two identical same age model s other than 1 has 19” and the other 21” staggered tesla wheels. Tesla supplied different tyres for each, both still original. I’ll do a stretch of road in each at precisely 60kmh for 5km and take the energy consumption for each journey, and report the results.18s are aeros though which gives a 5-10% increase in range from what i've read.
This differential is justified based on the 20” non-aeros for the P+Tesla quote all their ranges NEDC: LR AWD 620kms, P3D 560kms. My S100D 660kms (but best I have done is 580kms).
The aerodynamics of the wheel seems to be the difference people are getting in range. There are plenty of tests with the 18" wheels, aero covers on then off. Same wheel, same tyre and pressure. 5-10% improvement just with the covers. It was being discussed on the model 3 section the other day, putting a cover over the 20" for trips. I’m keen to try something when I get mine. 5-10% is a big difference on a trip of 300+ km. The 18, 19 and 20" wheels are all the same width, so with some careful pressure adjustments, I’d say they’d have a similar rolling resistance (which is different to aerodynamic drag).
However, the original poster mentioned Tesla said him that P Std was less range than the LR AWD - this is utter rubbish. It has been repeatedly shown they are identical, with 18” aeros
Nextmove in Germany recently did side by side testing of model 3 with and without aero wheel caps on the autobahn at 150km/hr. The difference was 3%. At our typical highway speeds I would expect slightly less difference.
The larger Tesla wheels are heavier so the greater unsprung mass will lead to less range. The stock tyre compounds used are also different with less range from the stickier compounds used on the performance models.
If I recall correctly, there's a quoted 10% efficiency gain comparing the 18" with caps vs. sports rims.3% isn't much difference is it, I thought I'd read somewhere it was more than that.
Glovis Champion is bound for Europe.
New source. Panama Canal bookings
:: BOYD - Steamship Corporation - Agents at the Panama Canal ::
Latest in Tracking spreadsheet
Public - Google Drive
Container ships FTW at the moment
