Brissienew
That’s good to know. Hopefully it is the same for all other cars.the fit and finish on mine is exceptionally good.
Ravens can have ludicrous on continuously. It is not in beta.
Isn't it more like 'Sport' vs. 'Chill' acceleration settings? As in, switch into it and the software allows more power to be drawn from the battery for as long as you remain in that mode, whether you're accelerating from a standstill or not?
A quick question about charging.
Does anyone know how to charge Tesla 3 in destination chargers that have the normal model S connector for charging as opposed to CCS?
Well since Hulu doesnt work in Australia you'll need to run Hulu through a browser proxy.
You can actually setup your own web proxy service through Glype or other web proxy services and it'll also run over the internet. Maybe even using a CDN for better localised caching?
From there you'll have to access the website in your car and you should theoretically be able to access blocked domains in Australia.
I believe that you can setup a custom DNS with Glype too so you might be able to use a 'SmartDNS' to further get around the block.
I dont actually own my Model 3 yet so I cant test any of this although, I'll try set something up and maybe someone can try it out.
Of course, this is all proof of concept at the moment.
Nevermind that it causes bad acceleration/deacceleration headaches. Well known problem with performance Teslas.
I confess I've yet to experience this feature. Guess I'll just have to redouble my efforts.
well they'll get plaid mode which is same thing just different name.
kinda it also heats up the battery etc. You wouldnt really just be driving around with it. It also damages the battery.
The other issue is that once you get to around 3 seconds of 0 to 60 you have completely unusable acceleration on any kind of road. It is just too fast for everyday use.
Plaid is not Ludicrous. It supposedly is reserved for the new Roadster (but now S & X also) which is quicker than Ludicrous. Plaid will have a different drivetrain and 3 motors. M3 does not get Ludicrous. You can drive on Ludicrous all the time and there is no harm. If you want Ludicrous + or the old Launch mode, you need to heat the batteries for lower impedence and higher electron flow. Then you can "launch" the vehicle from a standing start with reputedly up to 30% more power.
Headaches (more likely nausea) occurs when you pull more than 1G which is what happens under Ludicrous. Acceleration with L+ is mid to low 2's, and Plaid 2 and sub 2. (performance Roadster will be quicker). When asked the question, Elon said "how quick do you want to go?!"
The acceleration is too ludicrous and one false step on your pedal in a parking lot and your model s is toast.
Mhm, yeah Tesla dont provide network settings, at all so instead of doing the entire network through a proxy you'll have to send it via a web proxy on the browser. You can setup a custom DNS on the proxy itself not the Tesla.Tesla don’t use the dns server provided by DHCP, and you can’t set it to a custom server, so this approach is unlikely to work without some specially configured equipment.
I had this exact concern prior to picking up the car. But the throttle response is so precise I just can't see it happening in practice.
Also, there's a feature for that.
Any Tesla is so quick that if you stomp on the accelerator because you thought it was the brake you are in for a very bad time.apart from those cars where the "accelerator pedal got stuck in the parking lot" storys ehh.
Mine too, apart from one tiny pinprick paint nib. Perfect alignment too.Also, forgot to mention, the fit and finish on mine is exceptionally good. Not a blemish, mark or scratch. Alignment of panels absolutely perfect so hopefully this can allay some people’s fears.
Well that “rumour” is completely false. Yes, a BEV with a Type 2 Mennekes or CCS2 charge port could rock up to a Tesla Supercharger outside of North America and physicially plug in... but nothing would happen.That is also why non Teslas can plug into EU superchargers and rumour has it some of them can even get a very, very low AC charge from a supercharger which is used to establish communication with the car.
While true, Tesla have had an open offer to other manufacturers to open the charging network to others in return for an agreement to contribute to the further development of the network. With the move to CCS in the Model 3, this is a pretty viable option outside the US, but to date, no manufacturer has offered to join the fight. As I understand it, the protocol to read the VIN from the vehicle over the charge cable is part of the standard communications protocol, so anyone could participate.When you plug in your car into a Supercharger it does a handshake with the vehicle, confirms your VIN, account and makes sure your not blacklisted (eg: salvage)
Any other car connecting to a Supercharger would immediately fail the handshake and not get charged up.
The Tesla supercharger network is one of the biggest selling points for Tesla and they can control everything about it since its their own home grown network, I highly doubt they will be selling off space to other manufacturers any time soon.
