Many things have changed since the 2016 unveil, I'm well aware of the 8 modules shown in the animation at the unveiling and for this reason I assumed that the small battery car would be 6 modules and the large battery car 8 modules. But the ratio of ranges is not close to 4/3... that something was lost in translation.
Model 3 unveil last year showed battery consisting of 8 modules.
Unless 2 of those modules do not contain actual cells the report is wrong.
Speculation ran off track.
can anybody give link to info on 3 modules version, because I'm skeptical too. And no Electrek doesn't count as source, because they post anything about Tesla truth or rumor without possibility to distinct
Elon said 310 for LR, but there are pics of cars reporting 315.
315/220 = 1.43, 310/220 = 1.41
@LHC
I've already started to object but than redone the known numbers and I have to agree, they do not fit 8 module configuration at all. Elon said 310 for LR, but there are pics of cars reporting 315.
Indeed something I would expect from 3:2 config.
What about voltages though?
I don't see those three modules running in series though, 220 would end up being 260V max, kinda low. But on the other hand I also don't see them being in parallel at 400V each. To many HV pieces.
I'd guess, they have reduced those 8 modules down to 6, each at ~70V.
LR version gets 6 modules in series, and base version gets just 4 in series (270V max).
I am sure of only one thing: I am wrong.
wk057 just shot this down along with the C and D quote, apparently there are 4 modules with series groups of 23, 25, 25 and 23 cells. The small pack is made by removing cells from each module.The Model 3 launch gives us a bit of insight into the Semi battery. Elon's statement to Car and Driver that M3 has 3 modules means that these are big, ~25kWh, 400V modules that can be stacked to any pack size that's a multiple of 25kWh..
Also the mass differential between the two models gives us a clue as to module energy density. The difference is 265lb, but there's likely a stiffening bracket in place of the missing module on the 220mile car and there's likely some extra weight on the 310 mile car for additional wiring and possibly other stuff. I feel fairly comfortable placing module weight at 270lb and module energy at 25.5 with 24.5 of that being usable. This gives us a module level energy density of 200Wh/kg, 600kWh would be 6600lb. I can see a truck with modular battery capacity so that the truck's range and cost can be adjusted as needed.
I'm no semi expert though, make of his what you will.
some numbers from Mirai: FC stack is about 2kW/kg, probably 200 kW with such big buffer could be enough but let's 300 kW 150kg,While this information is old I didn't see it shared here, and it should help estimate what Tesla will/needs to do.
From the Nikola One video: They estimate that they can get 0.58 miles per kWh of electric energy. And they use 100kg of H2 to get 2,330kWh, 70% efficient, for 1,351 miles of range. (And they use 320 kWh of Li-ion batteries to buffer the power from the fuel cell.)
So how many kWh of batteries can you get in the same weight/space as 100kg of H2, the holding tank, and the fuel cell?
So it would seem if Tesla can put 1MWh of batteries in a Semi you could get a range of almost 600 miles; which seems reasonable to me. (The numbers probably wouldn't be that good because the required batteries would weigh more than Hydrogen would.)
This is interesting. Using their assumption of 0.58 mile/kWh and 7.5 mpg diesel leads to a displacement ratio of 12.93 kWh/gal diesel.While this information is old I didn't see it shared here, and it should help estimate what Tesla will/needs to do.
Very cool. Tesla could use a bunch of these vans too. Where is this Sprinter idea coming from? I've seen another reference to it, but have not be following closely enough to know what it triggering it.Jhm
I'm assuming the other thing with the semi will be a Sprinter style commercial van. It requires relatively little design relative to a car and would, like a Semi, have a big impact on gas consumption per vehicle. This is a big market and serves many of the same big customers. They only need one of UPS, FedEx, Walmart or a couple other large shippers under them to support a commercial van.
What impact would 50,000 or 100,000 annual Sprinters have on the market. I assume they run 200 urban miles a day and a gas version would get about 12-14 mpg. I assume this is about 10 times the fuel of an average car. Relatively modest production seems to have a pretty big impact.
Sprinter vans and semi trucks are completely different markets, not to mention design architecture.Very cool. Tesla could use a bunch of these vans too. Where is this Sprinter idea coming from? I've seen another reference to it, but have not be following closely enough to know what it triggering it.
I looked up the Sprinter and found that it is diesel. Of course, a lot of other commercial vans are gasoline powered. So the fuel offset of commercial vans will be both diesel and gasoline. Some major European cities will ban diesel by 2025. So this market is cracked wide open for alternatives to diesel vans.
I suspect there will not be any sprinter like van until the Tesla pickup truck. Those could share the same platform.
I think they are going after the semi truck (on highway & heavy haul) market because it's the one application where traditional truck OEMs seem to think it can't be done. The medium duty/urban/bus market is already flooded with different types of hybrid/BEV powertrain options. Also, JB mentioned the on highway & heavy haul market consumes a significant amount of fuel, so it's a good strategic move based on their mission statement.Yes, Tesla seems to be avoiding the medium duty market where EV seems to make a lot of sense. They undoubtedly considered all vehicle types, including buses. They picked semi as the best strategic move. One reason may be that the chassis did not require a lot of new R&D.
I work for a consumer goods manufacturer that I will not name. We bottle water, soda and an array of snacks. We operate one of the nations largest fleets of trucks and like FedEx and UPS we use Semi and commercial vans depending on the logistical requirements. UPS and FedEx use semis, but probably 10 times as many local Sprinter and larger Grumman style trucks.Sprinter vans and semi trucks are completely different markets, not to mention design architecture.
10,000 psi/700 bar Hydrogen is 42kg/m^3, so 2.38m^3 for the 100kg of hydrogen itself.
If Model S packs are 112" x 70" x 5" it'd be 0.642m^3, so you'd be able to get about 370kWh of Model S battery in place of the hydrogen. At 0.58mi/kWh that would only be good for a bit over 200 miles. But, Nikola has a 320kWh battery as well. If Tesla's density were the same, and you add and round to a total of 700kWh, at 0.58mi/kWh it'd be 400 miles of range.
11 hours at 70mph would be 770 miles. Moar battery.
