dhanson865
Why was there no discussion at all about FSD capabilities on the Semi?
Because FSD won't happen on the Semi for several years after they sell the first hundred thousand. No reason to discuss it now.
The smaller black truck has the impressive 500 mile range that Elon was talking about.
The large truck is the 300 mile truck from the "300 or 500 miles" range on the semi page.
</cynicism>
Anyone have a link to a complete video from Tesla? Not the fan videos but Tesla's? the web connection simply did not work so i quit and went to bed (east coats, it was late).
Can't find one on the Tesla web site or on YouTube except lots of fan videos with wiggly handheld cellphone videos. (No offense, glad they were there, but...)
youtube media
Thanks!
So full load, Tesla is at 2kwh/mile while diesel is at 4.5 mpg to be a bit generous. This gets to a electricity to diesel replacement ratio of 9 kWh/gal diesel.
Months ago we had debates about this. For EV autos, it is about 8kWh/gal gasoline, and fuel density arguments would imply 9kWh/gal diesel. So it is nice to see some confirmation of this. Other folks had argued that aerodynamic and roll resistance unique to semis would imply a much higher ratio of electricity needed to displace a gallon of fuel, a situation that would make EV economics worse in comparison to diesel. Fortunately, Tesla has achieved a .36 drag coefficient comparable to .65 to .70 for other semis. Tesla is owning the aerodynamics.
On implication of this displacement ratio is that if we want to relate average efficiency for the Tesla to 6 mpg for diesels, this 9kWh/gal ratio implies 1.5kWh/mile. So while there are myriad factors affecting efficiency, this is a nice ballpark figure for average use.
80k lbs with a 5% grade is about 8 kWh per mile. So net > 6 kWh.
Thinking about this issue more, the truck will probably have a large resistance heating unit in the cooling system. They can run that against the cooling system. 20kW would seem achivable without too much effort. The truck will have a decent sized radiator too.
The truck should almost never be at the top of a pass with an almost full battery. But AFAIK Tesla has to design the Truck so that regen always works.
This is actually fairly easy. You only charge to 70% of the battery. There are a number of reasons why this makes sense on a Semi with a 1,000,000 warranty. It solves the regen problem, prolongs the battery life, reduces the perceived degradation, and reduces the perceived charging time.They are also going to have to figure out a way to get max regen braking at all times, regardless of battery charge level. you can't have a loaded semi with half regen going down the grapevine. Trucks use a combination of gearing, engine braking, and service brakes to control loads, with no engine or transmission brakes on an electric they can't rely on service brakes during times of high battery charge.
-Jim
Non-truck driver here, so please correct me where I err. Are there two types of jack knifing , the first being the tractor stays straight and the trailer swings around (trailer at 90 degrees to direction of travel (DoT)), and the second being the tractor gets turned and the trailer pushes it the rest of the way (tractor at 90 degrees to DoT)?
If so, and assuming the 4 rear motors each drive a set of wheels, couldn't the vectored torque steering go a long way to prevent the second form?
Further, with computer stability control, couldn't the additional control also reduce the first type of jack knife by providing more opportunity to keep the king pin in front of the trailer center of mass?
Additionally, with regenerative braking, tractor torque vectoring, and two sensors on the kingpin for angle and force, the tractor could help prevent lock up of the trailer brakes, and anticipate an out of alignment issue. (Also detect stuck trailer brakes/ flat via drag profile.)
Realizing of course, the real world situation may not provide room to prevent knifing in all situations (emergency braking while on a curve).
I may be reaching a bit, but with the new levels of control, I do think they can apply some of the knowledge they have developed via Tesla stability control and SpaceX landings. (Oh, maybe the aerodynamic wings can also be air brakes?)
Then your 500 miles range turns into 350This is actually fairly easy. You only charge to 70% of the battery. There are a number of reasons why this makes sense on a Semi with a 1,000,000 warranty. It solves the regen problem, prolongs the battery life, reduces the perceived degradation, and reduces the perceived charging time.
-Jim
I suppose it is possible for an unstabilized tractor to somehow get turned around while the trailer itself stays straight and aggravates it. I don’t think that is what Musk was suggesting he has solved. And all tractors today have ESC (electronic stability control) so this is not likely without an external trigger (an external lateral force applied to the front of the tractor, such as being hit by another truck). When a trailer jackknifes, it doesn’t necessarily stop at 90 degrees. It can keep right on going and penetrate the cab. It’s a big, dangerous deal. I’ve had the privilege of testing jackknife scenarios on the track (as the engineering passenger, I leave the test driving to the pros!). Trailers carry a tremendous amount of force, and can yank the tractor 180 degrees off kilter, or roll it if the trailer rolls (the king pin is mighty strong, and can lift the tractor off the ground when the trailer rolls). In our case, we had outriggers and jackknife chains to keep the rig from killing us!
Without sensing equipment in the trailer, I don’t see them implementing some magical new anti-jackknifing tech in the tractor. I could be wrong, but I just don’t see it unless they are supplying some new trailer tech. But that would be overkill anyway, because all that is necessary is simple ABS units on the trailer and dolly axles (which is becoming common today).
In practice, tractors pull many trailers. In fact, in a single day, a tractor may very well pull at least two different trailers. One can’t assume that a trailer will have special sensors installed. And installing sensors on the kingpin would be a significant mechanical challenge. Perhaps they’ll try to do something on the fifth wheel, but still the mechanical challenges are great. Even with that, I’m not sure the tractor could keep a trailer from jackknifing by its own maneuvers, at least assuming the tractor is constrained to it’s own lane.
His whole thing regarding jackknifing was just noise, as far as I can tell. But who knows, maybe Jerome has sprinkled in some powerful magic...
Wow, that had to be some crazy testing! I'd used 90 dress for brevity, it'll turn till it runs out of inertia.
Agree with pretty much everything. What I was suggesting doesn't require trailer mods. They must already have some sensing of trailer position for the side wings/ skirt adjustment. Trailer loading could be done by a set of strain gauges mounted at appropriate points on the 5th wheel (I'd incorrectly referenced kingpin).
Not sure what they are doing either, just spit balling what might be possible.
This way they could even keep everything at 400V nominal and share all their power electronics designs between platforms.
