spdpsba
Have you not tried?There is no manual returning to the original position. It works similar to the indicators in that is always returns to the central position itself.
The fact is that if you don’t have auto high beam enabled then there isn’t a way to bring up the pop up without making the high beam come up, whether you push or pull the stalk.
Simple step if you don’t use auto: enable auto —— pop up appears ———- switch fog lights ——- disable auto
Hope that helps
