Charging definitely creates heat losses right inside the battery so yes charging does warm the battery. Not a lot, though, unless you are Supercharging. In winter, it's a good idea to use the charge timer and set it to a time that charging finishes just before you leave. But as you say, sometimes the timing doesn't work.
The energy needed to heat something up depends mostly on the mass of an object. How much energy is needed to keep it at a certain temperature depends on a lot of things. Mostly difference between temperature of the battery vs outside temperature. How much airflow there is, how much surface area it has in relation to the mass and so on. Kind of hard to calculate. I think as long as we are talking about 1-3 hours it should all be fine. You shouldn't have to worry.
Honestly, I think the car should have an option where you can tell it, 'I want to leave at 8 am'. The car then does whatever it needs to do to get ready. Charging, preheating the battery, heating the cabin. How much it needs of everything depends on many things, like state of charge, desired state of charge, outside temperature, battery temperature. It would be a pain if we had to do all of that manually. The car has all the info, just let it handle it. Someone suggested that to Elon 2 years ago at a public meeting. He nodded and said I agree. We are still waiting for it
It goes without question that there should be a way to at a minimum, schedule the end-time for a charge. I don't think anyone really disagrees on that. I've written to Tesla about that a couple of times in my letters requesting a battery preheating option.
As for the affects of charging on battery heating, and the affects of a warm battery on efficiency, I have some interesting data to share, from the last three mornings.
As some of you may know, since last February I have been recording the regular trips between Ithaca and Syracuse my wife and I make in our P85D, and comparing our efficiency results against what EV Trip Planner would predict. I started doing this because at the time I was concerned that we were not seeing the efficiency gains from Torque Sleep that others were seeing.
In addition to the metrics available through the car, I also attempt to record outside temperature, by looking at it regularly during the trip, and then estimating an average, and wind speed, using the tool available in the thread here:
Tool to estimate the head wind while driving !. I ask my wife to do the same thing. I also record weather conditions like rain, snow, etc.
The last three mornings are interesting for the following reason. The temperature my wife reported was 10 F each morning. She reported wind speed of a headwind of 4MPH one morning, and 5 MPH the other two. She drives the same speed on the highway each day, and I also use Visible Tesla with geofencing to record when she leaves and arrives, and will include that data, but the bottom line is that these three trips, for all intents and purposes, were about as similar in conditions as we could hope for. The one variable was battery temperature based on charge time. On Monday morning the pack was cold, as it had barely charged at all overnight, since it had charged to 90% the night before. On Tuesday morning the pack was somewhat warm, with the charge having completed about 90 minutes before my wife left for work. This morning the pack was apparently warmer, as my wife left just 30 minutes after the charge completed. The data is below, and I think it tells quite a story about the impact of charging on battery temperature and efficiency.
| | Distance | RM | Total | Average | Cabin | Outside | | Weather | Duration |
Date | | (Miles) | Used | Energy (kWh) | Energy (Wh/mi) | Temperature | Temperature | Wind | Conditions | (Minutes) |
1/4/16 | | 53.9 | 69 | 19.9 | 370 | 68 | 10 | 4HW | Flurries | 65 |
1/5/16 | | 53.9 | 62 | 18.2 | 338 | 68 | 10 | 5HW | Clear | 64 |
1/6/16 | | 53.9 | 59 | 17.1 | 318 | 70 | 10 | 5HW | Clear | 60 |
Note that this morning's trip, 1/6, was the fastest, had the cabin heater set two degrees higher, and in spite of that was still the most efficient by far.
