MYLR
White
19 inch Gemini's
5 Seat Black Interior
Tow Hitch
OD: May 8
ODD: June/July
EDD1: May 27-June 10
EDD2: June 4-June 10
EDD3: May 29-June 7
VIN1: May 22
Manufactured1: May 22 Fremont
DD1: June 5
Order placed on Hold: June 1
Hold Expired: June 15th
EDD4: June 29-30
VIN2: June 16th (PF807XXX)
Manufactured2: ??? Fremont
VIN2 Removed: June 20th
VIN3: June 22nd (Austin)
VIN3 Removed: June 23rd
Order placed on Hold Until July 1: June 23
VIN4: June 28 (Freemont)
VIN4 Rejected at delivery: July 1 (roof seal problem)
Order placed on Hold until July 3rd: July 1
EDD5: July 1- July 8
VIN5: July 4
Manufactured5: July 3 (Fremont)
EDD6: July 7 - July 14
EDD7: July 14 - July 23
Denver, CO
Delivered: July 18
Car is great. It has a couple of flaws that I had them note, but I do not currently intend to pursue fixes.
The gap for the hatch is visibly different between left and right. I'd estimate the gap is 100% bigger on the right side vs the left side. The hatch opens and closes properly, isn't rubbing, leaking or causing noise so I think I don't want them messing with it. The other panel gaps all around the car are fine. The gap around the frunk is even all around, unlike the new P model they loaned me for a few days.
There are a few small paint defects. A couple pieces of dust trapped under and a bubble or 2. None are that visible to me so I will ignore.
The place on the rear bumper where the door that covers the tow hitch mounts is missing some plastic, so not all the clips engage. It stays put so I will also ignore.
They also delivered the car to me without temporary registration tag on the back. I noticed the next day and they emailed me the tag and I printed it, mounted it on cardboard, vacuum sealed it in a food saver bad and mounted it to the back of the car. That should last the 60-90 days it takes around here to get permanent license plates.
Overall its great and drives well, I expected some quality issues that I wouldn't expect from Toyota, GM or other mainstream automaker. Will drive it for a little bit and if no powertrain or driving issues come up then I will add the acceleration boost to it.
