because...physicsextrapolated for one data point to an impossibility.
Perhaps you can explain how you extrapolated for one data point to an impossibility.
I would probably use the word 'simulations' rather than 'testing'.Do you think this was a result of testing?
I think they made a simulation, hoped for a certain result, didn't reach it, but consistently got over 215 miles of range when going through the EPA's 5-Cycle testing procedure.Do you think it was set as a design goal instead of 200?
The only misdirection, if any, is that Elon Musk has only spoken of minimum EPA, or minimum 'Real World' range. Thus far there has been no notation of an expected maximum. I do know that at one point he wanted to offer a $50,000 (after incentives) version of Model S that had a 320 mile range. But reality set in and made that impossible. I'm sure Elon would love to fix that with Model ☰.Or do you think it's a complete misdirection and the true range of the base model is much higher?
There is nothing to be gained from bickering and pecking; please stop.I'd be happy to, right after you explain the scientific methods you used to determine that you gained 10% at 300ft.
I would rather Tesla work towards a 200mi range in cold weather, than to worry about 200mi EPA. Especially since the EPA 5-cycle test doesn't take into account cold weather.BTW, the 0.7 factor in the formula I referenced doesn't just account for low temps, but also normal driving speeds. I don't think anyone who orders M3 plans to drive it like a Leaf. Besides, 215 is the bare minimum EPA range announced. So much can change between now and launch. Keep in mind that the apples to oranges comparison won't just magically go away once the Bolt is launched. I guarantee you that Elon will pay attention (and adjust accordingly) to what real world range Chevy (or any other manufacturer) actually ends up with prior to M3 launch. M3 absolutely has to be the range champ for the money.
Oh, and don't forget the biggest and most important factor of them all... there will be an optional higher capacity battery, perhaps even more than one!
Detailed Test InformationI would rather Tesla work towards a 200mi range in cold weather, than to worry about 200mi EPA. Especially since the EPA 5-cycle test doesn't take into account cold weather.
That is a low speed cold temp test. Which is useful, but not what folks are talking about here. Most are concerned about range doing normal interstate speeds in cold weather.Detailed Test Information
Click on Test Details and you should see that they do have a cold temperature test. Or am I misunderstanding what you're describing? I haven't followed this conversation 100%.
It's too confusing to customers, while competition would just state their max to look better. You'd need yet another industry standard to hope to improve advertised range estimate as compared to reality. The cold weather and life shortening max charges should be factors included in the advertised range.It would also be a nice surprise if Tesla rates the Model 3 at the 80% charge point instead of the 100%. But I understand that isn't likely.
The problem with not doing it that way is the end user, who has been told not to 100% charge (often), won't see the full range.It's too confusing to customers, while competition would just state their max to look better. You'd need yet another industry standard to hope to improve advertised range estimate as compared to reality. The cold weather and life shortening max charges should be factors included in the advertised range.
Any idea how to model this question by first principles ? That would be cool.
I easily believe it due to the tremendous weight reductions and known battery density improvements.With tesla's track record of over promising and under delivering, i say the 215 miles spec is so they can one up the competitor's number to make the model 3 look better. I say the 215 miles is the best case range for the M3. Those who believe it is real can continue to live in their fantasy world. I wont believe it until i see it in real life under real world conditions.
I disagree, Elon has spoke about his concern a few times that the third generation car needs a real world range of at least 200 mi. so he'd always considered a buffer of 20% if I recall correctly. If this holds then I'd say best case range would be more like 240-250. EPA might give an estimate closer to 215I say the 215 miles is the best case range for the M3.
It might depend on where the "real world" is located Warmer areas - no doubt. Colder areas - less likely.I disagree, Elon has spoke about his concern a few times that the third generation car needs a real world range of at least 200 mi. so he'd always considered a buffer of 20% if I recall correctly. If this holds then I'd say best case range would be more like 240-250. EPA might give an estimate closer to 215
Are they not built on the same technology???? Yes they are on different "skateboard" platforms, but the battery technology is the same, therefore, if you take the size of the vehicle, Model ≡ being smaller, and the battery technology into consideration, then my statement is true. The Model 3 with a 60kWh battery should easily be able to do 215 EPA Miles.
Yes there are threads that state the Model 3 will have <60 kWh battery, but as we have seen with the Model S and how Tesla has been changing the 60 kWh->70kWh->75kWh, and the 85kWh->90kWh battery, we can assume that by the time the Model ≡ will be at least a 60kWh pack on a different "skateboard" platform.
80 mph is only for a few seconds but 60-65 is sustainedI don't keep up with the EPA test...but how long does it maintain 80mph? In bursts? or for a sustained period of time?
Over my head and past my prime. I see though that the solution is a differential equation. While driving home today I kinda sorta convinced myself that the pull would decrease proportionately to the square of the distance.Navier-Stokes. Let me know how you do.
