Wow lifetime of 340 what are you doing?? Do you have stock tire size?I'm sorry to report that the Model Y is a thirsty girl. It's probably best to keep your range in percentage and know it's thirsty. Lifetime maps shows less than 75% efficient on our 2020 MY.
Look at his sig, then imagine his heavy right foot... If you're easy on the go pedal with a LR can get down to 250 wh/mi so AT 340...Wow lifetime of 340 what are you doing?? Do you have stock tire size?
Something seems off unless you're driving 80mph most of the time
His point is. A new EV driver needs to teach their foot to “chill”. One way to learn that is by forcing it. If they are in pain, that’s why their wh/mi is high. If they are driving efficiently they won’t even notice the change.We really need to see the terrain you're driving on. Any advice here is skewed toward individual results based on region.
Chill mode? My "chill" mode is my right foot. I rarely punch it, because...because...well...I'm older, been there, done that. It's not a thrill anymore. I've grown up. (HAHA!)
29k miles, several road trips, DFW driving (actually, mostly highway). I'm at 284 Wh/mi lifetime. Not obsessing about range, no longer any range anxiety.
I guess I'm REALLY getting old.
Likely you drove back down hillOP here again. It seems like my wh/mi has come down to 256. I dunno what I did. It is quite strange.
The MY has seen a lot of highway miles. I've had it on Turo for a year or so. Still there but now my daily this last year. It just loves the juice. I do have the 20in rims and yes, way early on I've changed tires to the Comp 4S. I'm actually on my 4th purchase set for the rear. I've done two autocross events over the last two years and a few track nights at the 1/8 track and the 1/4 track. I really don't think that affects the consumption as much as these Texas highways. You're usually doing 80 somewhere on the highway.Wow lifetime of 340 what are you doing?? Do you have stock tire size?
I’m sitting around 273 wh/mi lifetime average over almost 2 years and just under 20k miles. That includes 2 MN winters, too. How fast are you driving on the highways? The efficiency noticeably drops as you go above 60 MPH. I suspect in TX you’re burning a few more electrons for the A/C, too.We really need to see the terrain you're driving on. Any advice here is skewed toward individual results based on region.
Turo - that can explain a lot, too!The MY has seen a lot of highway miles. I've had it on Turo for a year or so. Still there but now my daily this last year. It just loves the juice. I do have the 20in rims and yes, way early on I've changed tires to the Comp 4S. I'm actually on my 4th purchase set for the rear. I've done two autocross events over the last two years and a few track nights at the 1/8 track and the 1/4 track. I really don't think that affects the consumption as much as these Texas highways. You're usually doing 80 somewhere on the highway.
The Y does have the 980 performance motor and I'm not sure if that really affected the consumption. Usually the difference in range between the MYLR and the MYP would be the rim / tire size.
Less launches and showing friends helps wonders. I think you naturally get better at one foot driving. Also as things warm up tire pressure goes up. Few pounds can make a significant change in efficiency.OP here again. It seems like my wh/mi has come down to 256. I dunno what I did. It is quite strange.
I reset it for you.OP here again. It seems like my wh/mi has come down to 256. I dunno what I did. It is quite strange.
It depends. You can burn thru a whole battery in 30 mins on a track. A 60 second autocross run will push wh/mi into the thousands.Sustained highways speed way more important to wh/mi than acceleration
What?That's because you're using the _brakes_
What?
Most good Tesla drivers on the street are using the brakes alnost-never. This maximizes regenerative braking and efficiency, thus rate of acceleraation is not that big a deal.
