Electric1
Where can I buy a single standard 19" wheel sans tire without having to buy an entire set of 4 that's being sold on Tesla's online store?
Tire rack has 19 inch wheels that will fit, but they will not match exactly.
- - - Updated - - -
> The problem is jacking up the car. [EdA]
Turns out NOT to be the problem I assumed it would be using a common everyday lightweight sissor jack. In the past I have used these handy jacks to lower the MS but assumed the MS was too heavy to be raised by them. Not so as it turns out, since when you begin jacking at LOW level the jack does not to lift much weight at all. By the time the jack assumes ALL the weight the force multiplier is much greater due to the geometry of the sizzors.
Be sure the sizzor jack you use is in 'new' condition and is clean and lubed. Then get a short length of hardwood flooring which usually has that routed-out groove on the under-side. That groove is where the curved top surface of the GM-style jack goes. This keeps it centered on the wood as the angle changes as the car is jacked up. Or simply receives the 'pin' on the top of sizzor jack that has a fully floating top piece (Ford, Subaru). BOTH styles of sizzor jacks will work for the MS. And the wood spreads the weight nicely over the plastic contact pad on the MS rocker.
Any wrecking yard can get you a mint sizzor jack for cheap. Get a piece of 1/2 inch plywood to use under the jack on soft earth.
PI would be concerned about the ability of just any scissors jack to hold the weight safely while changing a tire. A falling model S, even for a short distance could cost someone a finger. Some jacks from a junkyard might be for much lighter cars and even though they might be able to do the lift they might crush at a very bad time.
