ElectricIAC
Good-Natured Rascal
I’ve seen it on the desktop version of the site. I’ll grab a screenie when I can.Not it's not. 322mi range and 4.4sec (including rollout) vs. 310mi range and 3.2sec (not including rollout).
Good luck with that. Perhaps briefly there was some horrible error on the site but that is certainly not the norm.
What's the wheel size on "2019 Model 3 P/AWD"?
2020 AWD here. Swapped to display range before the update to 2020.4.1 and displayed range went up after updating. Range at 100% went from 309 to 319.
Now that 2020.4.1 has resolved all the weird stuff, I'm updating my spreadsheet. No original spreadsheet to post yet - I'm still working on resolving some discrepancies on some vehicles in my spare time.
But stuff is starting to make a lot more sense now. Again, orange cells are direct data from Tesla. No funny business here other than that scaling factor. Ignore Model Y for now; lots of guesses there and this is the wrong forum.
So does this mean the 2020 SR+ discharge constant is somewhere between 197 and 201?
The LR AWD got updates to match EPA, but the 2020 SR+ has always somewhat matched EPA right?
Quick update: I'm at 246 Rated Miles....ODO 3.5k Miles.
So this theory suggests the top 2.5 of the battery was hidden froYes, “constant” for discharge is about 197-201Wh/rmi. Would be great if you or others could verify it. Your battery capacity appears to be below 52.5kWh now so yours is not a candidate for testing the “inflated” rated miles theory detailed elsewhere. But you could still check the baseline discharge rate. Just need a long enough trip (>100 rated miles used...) and careful data capture.
managed to hit the solid line again in energy consumption. 215 exactly for SR+ 2020 on 2020.4.1. Does this mean they moved solid line to closer match charge constant ?Yes, “constant” for discharge is about 197-201Wh/rmi. Would be great if you or others could verify it. Your battery capacity appears to be below 52.5kWh now so yours is not a candidate for testing the “inflated” rated miles theory detailed elsewhere. But you could still check the baseline discharge rate. Just need a long enough trip (>100 rated miles used...) and careful data capture.
Why would the raw value for the 2020 P 18 be higher than the 2020 AWD?
