WA-T3sla
the time and temp applies to the latest build. They have it in Europe too. The clock app is a waste of space since it is just that, a clock. Nothing else. My guess is the USA will also revert at the next update.
In other news, I have just written to service help asking that tire pressures be displayed in Kpa as per the sticker on the door jamb, and which is the convention for tyre pressures as per my mechanical engineer daughter. Suggest as many as possible write in as numbers have more clout.
kPa is technically correct as the accepted SI units for pressure (even the tyre placard lists kPa and Psi but not bar), but my mind thinks in Psi for tyre pressures. It's easy enough to do a quick conversion from bar to kPa (just multiply by 100) but that means nothing to me. I can't multiply bar by 14.5 in my head to get Psi though, although I guess with autopilot on I could pull out a calculator and do the sums.
