Given a few apparent factors[1]:
- The fire appears to not be venting out the front, and thus not originating in the pack
- The car was supercharging
- Fire origination point seems to be rearward and upward
- Perhaps some impact (overload) affecting nearby charger cabinets and/or transformer
I suspect this may be an electrical connection overheating issue. A serious amount of energy (~135KW, >330A) is being conducted in the system.
Some earlier discussion of the HVJB took place, and while there may not be much in that box that's flammable, it's still not outside the realm of possibility. However there are also many other junctions and connection points in the system:
-Supercharger cable termination in the handle
-Car power inlet port/handle interface
-Cable connection to port
-Cable connection to HVJB
-Cable connection to pack connector
-Pack connector/pack interface
Not all of these would need to short out to get very hot. Just loose or dirty connections would suffice. Or damaged/faulty parts. Nor would the fault need to be where the cable insulation itself would fail and trip it's protective shielding.
We have examples of HPWC handles being very hot (130+ degrees if memory serves) as a result of issues either with dirty pins or marginal cable terminations within the handle. Those max out at 20KW of power. This is nearly 7 times that...
I've seen (and heard!) 400A connections cooking in panels... (while drawing far less than max load) as a result of loose connections. There's a tremendous amount of energy flowing there...
[1] Too early to call them facts
(on edit: having seen the longer video, I'm less inclined to think the supercharger/transformer hardware was being overloaded)
