AP2.0 Cameras: Capabilities and Limitations?
Discussion in 'Autopilot & Autonomous/FSD' started by lunitiks, Feb 20, 2017.
  1. eli_
    eli_ Member
    Bellevue, WA
    They're tiny lenses, like a cell phone camera, so the resolution is likely limited by diffraction in the lens. Adding more pixels won't help.
  2. electronblue
    electronblue Active Member
    Earth
    Yet one arguable leader in consumer car automotive vision — MobilEye — is doing exactly that: adding more pixels. I would assume they have their reasons. To assume the amount of pixels eg in Teslas (be it AP1 or AP2) would be optimal would be arrogant.
    Automotive lenses are not as small as cell phone camera lenses either. Yet for example Tesla’s lenses have ten times less pixels than the usual cell phone camera. It would seem like there is a middle ground where more pixels than eg Tesla has can help.
    We should also not forget that MobilEye has a very efficient vision network. It would not surprise me if they can process a larger resolution with less power requirements than eg Tesla with their NNs. Tesla on the other hand has had to downscale even their inputs.
  3. chillaban
    chillaban Active Member
    Bay Area
    FWIW downscaled higher resolution input often is better quality than a sensor that produces the target resolution, depending on your downscaling algorithm.
    Plus that way you always have access to the original resolution if you make a software breakthrough or want to bolt in out of band analysis on the frame that doesn’t need to run at high frame rates.
    You can always downscale. But you can’t pull new pixels out of thin air. And Tesla is past the production volume where they can retrofit cameras.
  4. banned-66611
    banned-66611 Guest
    Indeed, and for AI use you can run a simple edge enhancement filter before downsampling so that things like road signs are easier to read.
    Does anyone know the specs on the original AP V1 system cameras that could read road signs? Or the current ones in the Niro/Kona that can read road signs?
  5. dgatwood
    dgatwood Member
    Sunnyvale, ca
    At a cost in terms of low-light performance, of course. That's the caveat.
    My best guess is that the manufacturer offered them a good bulk discount on the newer sensors. Also, bear in mind that cameras and other similar parts only get built for a certain period of time, and after that, the price per unit skyrockets to get the manufacturer to continue building legacy parts. So if you're going to design something that will be included in cars for several years, you always want to start with a current-generation camera, not something from a previous generation.
  6. electronblue
    Earth
    @dgatwood All possible. But it is also possible they might use the added resolution.
  7. ChrML
    ChrML Member
    Norway
    600 000 - 800 000 cameras a year is not an insignificant volume though. For that volume, it's easy to justify a seperate production line just for that type of camera. I doubt Tesla has taken anything less than 10 years into account when contracting the vendor.
  8. CK_Stuggi
    CK_Stuggi Member
    Stuttgart
    At least that's the hope after the quick switch from AP2 to AP2.5 cams.
    Would be interesting to know how many AP2 cars are out there and hence how many AP2 cams are out there.
  9. MorrisonHiker
    MorrisonHiker S 100D 2021.4.11
    Colorado
    I haven't looked to the numbers to confirm but AP2 was in production for about 9 months, so a rough guess would be 75,000 cars.
  10. verygreen
    verygreen Curious member
    TN
    ap 2.0 and ap2.5 have identical sensor, just the color filter that's different. Also it's totally trivial to have support for both, Tesla just chose not to do it with a forceful assert in the code if the type does not match, but since they have identical NN so far - it's not really needed.
  11. CK_Stuggi
    CK_Stuggi Member
    Stuttgart
    Just for my understanding, we're talking physical filters on the identical sensor, correct?
  12. verygreen
    TN
    Yes. the physical color filters are different on otherwise same bit of silicon.
  13. scottf200
    scottf200 Active Member
    Chicagoland ModelX S603
    [follow red arrow above to see thread/post where above came from]
    Interesting that AP3.0 related cars and their new cameras may have a hard time with the red lights. From below and AP2.0 related cars (I think) you can clearly see the redish grey results on the red brake lights and red stoplights ... look a little orange.
