[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 3.18.21-rt19 ([email protected]) (gcc version 4.9.3 (crosstool-NG crosstool-ng-1.22.0) ) #1 SMP PREEMPT RT Tue Apr 25 17:30:31 PDT 2017
[ 0.000000] CPU: Cortex A57 Processor [411fd073] revision 3
[ 0.000000] Found vpr, start=0xec500000 size=ba00000
[ 0.000000] Early serial console at MMIO32 0x3110000 (options '')
[ 0.000000] bootconsole [uart0] enabled
[ 0.000000] Reserved memory: initialized node ramoops_carveout, compatible id nvidia,ramoops
[ 0.000000] cma: Reserved 64 MiB at 0x00000000e6000000
[ 0.000000] On node 0 totalpages: 954880
[ 0.000000] DMA zone: 5887 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 430592 pages, LIFO batch:31
[ 0.000000] Normal zone: 7168 pages used for memmap
[ 0.000000] Normal zone: 524288 pages, LIFO batch:31
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.0 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] PERCPU: Embedded 15 pages/cpu @ffffffc0ffe22000 s22016 r8192 d31232 u61440
[ 0.000000] pcpu-alloc: s22016 r8192 d31232 u61440 alloc=15*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 941825
[ 0.000000] Kernel command line: root=/dev/mmcblk0p2 rootwait ip=off ro console=ttyS1,115200n8 no_console_suspend=1 tegra_keep_boot_clocks bootpart=kernel-b envpart=2 sdhci_tegra.en_boot_part_access=1 mtdparts=mtd0:65536K@0K(whole_device),524288@0(stuff),524288@20709376(env),262144@21233664(recovery-linux-dtb),262144@21495808(kernel-a-dtb),262144@21757952(kernel-b-dtb),11534336@22020096(recovery-linux),15728640@33554432(kernel-a),15728640@49283072(kernel-b) tegraid=18.1.2.0.0 vpr=0xba00000@0xec500000 lp0_vec=0x10000@0xf7ff0000 earlycon=uart8250,mmio32,0x03110000 bl_prof_dataptr=65536@0x0f7fe0000
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Dentry cache hash table entries: 524288 (order: 11, 8388608 bytes)
[ 0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes)
[ 0.000000] Memory: 3668048K/3819520K available (8544K kernel code, 1064K rwdata, 3896K rodata, 1928K init, 759K bss, 151472K reserved)
[ 0.000000] Virtual kernel memory layout:
vmalloc : 0xffffff8000000000 - 0xffffffbdffff0000 ( 247 GB)
vmemmap : 0xffffffbe00000000 - 0xffffffbfc0000000 ( 7 GB maximum)
0xffffffbe01c00000 - 0xffffffbe05400000 ( 56 MB actual)
PCI I/O : 0xffffffbffa000000 - 0xffffffbffb000000 ( 16 MB)
fixed : 0xffffffbffbdfe000 - 0xffffffbffbdff000 ( 4 KB)
modules : 0xffffffbffc000000 - 0xffffffc000000000 ( 64 MB)
memory : 0xffffffc000000000 - 0xffffffc100000000 ( 4096 MB)
.init : 0xffffffc000ca7000 - 0xffffffc000e89000 ( 1928 KB)
.text : 0xffffffc000080000 - 0xffffffc000ca6b24 ( 12443 KB)
.data : 0xffffffc000e96000 - 0xffffffc000fa02f8 ( 1065 KB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Additional per-CPU info printed with stalls.
[ 0.000000] NR_IRQS:64 nr_irqs:64 0
[ 0.000000] Architected cp15 timer(s) running at 31.25MHz (phys).
[ 0.000000] Initial timer value: 0x0000000001c449fe: 0.94s
[ 0.000003] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 2199023255552ns
[ 0.000322] tegra-id: chipid=21817.
[ 0.000631] tegra-id: opt_subrevision=1.
[ 0.000946] Console: colour dummy device 80x25
[ 0.005089] allocated 16777216 bytes of page_cgroup
[ 0.005091] please try 'cgroup_disable=memory' option if you don't want memory cgroups
[ 0.005092] kmemleak: Kernel memory leak detector disabled
[ 0.005103] Calibrating delay loop (skipped), value calculated using timer frequency.. lpj=31250
[ 0.005105] pid_max: default: 32768 minimum: 301
[ 0.005165] Security Framework initialized
[ 0.005198] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.005202] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.005598] Initializing cgroup subsys memory
[ 0.005608] Initializing cgroup subsys freezer
[ 0.005613] Initializing cgroup subsys debug
[ 0.005631] ftrace: allocating 29023 entries in 114 pages
[ 0.033446] CPU0 capacity=752
[ 0.033486] CPU1 capacity=1024
[ 0.033504] CPU2 capacity=1024
[ 0.033524] CPU3 capacity=752
[ 0.033544] CPU4 capacity=752
[ 0.033565] CPU5 capacity=752
[ 0.033590] hw perfevents: enabled with arm/armv8-pmuv3 PMU driver, 7 counters available
[ 0.052166] Brought up 6 CPUs
[ 0.052173] SMP: Total of 6 processors activated.
[ 0.053148] devtmpfs: initialized
[ 0.062972] Initilizing CustomIPI irq domain
[ 0.065119] pinctrl core: initialized pinctrl subsystem
[ 0.065490] regulator-dummy: ; Rail ON
[ 0.079170] Initializing plugin-manager
[ 0.079210] Plugin-manager not available
[ 0.079581] Adding domain adsp-pd to PM domain ape-pd
[ 0.080843] NET: Registered protocol family 16
[ 0.081294] console [pstore-1] enabled
[ 0.081299] pstore: Registered ramoops as persistent store backend
[ 0.081303] ramoops: attached 0x200000@0xea200000, ecc: 0/0
[ 0.081775] I2C first dynamic bus number based on alias = 9
[ 0.088753] cpuidle: using governor ladder
[ 0.095144] cpuidle: using governor menu
[ 0.095748] bpmp: waiting for handshake
[ 0.095754] bpmp: handshake completed
[ 0.095777] bpmp: synchronizing channels
[ 0.095789] bpmp: channels synchronized
[ 0.095793] bpmp: connect returned 0
[ 0.096080] tegra186-pmc device create success
[ 0.096140] create /sys/kernel/debug/PMC/boot-chain-type
[ 0.096150] tegra186-pmc: prod list not found: -19
[ 0.096225] padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registered
[ 0.096230] PMC: configuring io pad defaults
[ 0.096243] T186 pmc padctrl driver initialized
[ 0.096249] ### PMC reset source: Software reset
[ 0.096252] ### PMC reset level: L1
[ 0.096255] ### PMC reset status reg: 0x2d
[ 0.096368] vdso: 2 pages (1 code @ ffffffc000e9d000, 1 data @ ffffffc000e9c000)
[ 0.096433] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.098255] DMA: preallocated 2048 KiB pool for atomic allocations
[ 0.099862] tegra_powergate_init: DONE
[ 0.100185] DTS File Name: arch/arm64/boot/dts/tegra186-tesla-das-hw20-rev-c.dts
[ 0.100198] DTB Build time: Apr 25 2017 17:30:52
[ 0.100220] Tegra reboot handler registered.
[ 0.101007] Registering Tegra186 clocks (this may take a while)...done
[ 0.101922] tegra186-pinctrl 2430000.pinmux: Prod-settngs not available
[ 0.103054] tegra186-pinctrl 2430000.pinmux: lookup the user state drive not found
[ 0.103067] tegra186-pinctrl 2430000.pinmux: lookup the user state unused not found
[ 0.103077] tegra186-pinctrl 2430000.pinmux: Probed Tegra pinctrl driver
[ 0.110440] mc: mapped MMIO address: 0xffffff8000520000 -> 0x2c10000
[ 0.110464] mc: mapped MMIO address: 0xffffff8000540000 -> 0x2c20000
[ 0.110485] mc: mapped MMIO address: 0xffffff8000560000 -> 0x2c30000
[ 0.110503] mc: mapped MMIO address: 0xffffff8000640000 -> 0x2c40000
[ 0.110527] mc: mapped MMIO address: 0xffffff8000660000 -> 0x2c50000
[ 0.110577] mc-err: Set intmask: 0xf3140
[ 0.110713] ecc-err: dram ecc disabled-MC_ECC_CONTROL:0x0000000c
[ 0.111968] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CTRL_0 = 3
[ 0.111981] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CNTRL_24(PMU_INT) = 320
[ 0.117893] tegra18x-reset 5000000.clock: registered 193 resets.
[ 0.120410] bpmp d000000.bpmp: firmware tag is 489f988b2661add6508874c39562c155
[ 0.124690] GPIO chip tegra-gpio: created GPIO range 0->252 ==> 2430000.pinmux PIN 0->252
[ 0.124880] gpiochip_add_data: registered GPIOs 0 to 255 on device: tegra-gpio
[ 0.164571] sys-3v3: 3300 mV ; Rail ON
[ 0.164828] sys-5v0: 5000 mV ; Rail ON
[ 0.165264] vdd-1v1: 1100 mV ; Rail ON
[ 0.165576] vdd-1v2: 1200 mV ; Rail ON
[ 0.165877] vdd-1v8-ddr: 1800 mV ; Rail ON
[ 0.166138] vdd-3v3: 3300 mV ; Rail ON
[ 0.166415] spmic-sd4: 1100 mV ; Rail ON
[ 0.166731] vdd-1v8-pll: 1800 mV ; Rail ON
[ 0.166971] spmic-ldo1: 800 mV ; Rail ON
[ 0.167234] vdd-v3v-ao: 3300 mV ; Rail ON
[ 0.167560] en-vdd-rtc: 1100 mV ; Rail ON
[ 0.167831] vdd-1v8-ao: 1800 mV ; Rail ON
[ 0.168062] vdd-1v05: 1050 mV ; Rail ON
[ 0.168326] spmic-ldo8: 800 mV ; Rail ON
[ 0.169196] vgaarb: loaded
[ 0.170921] SCSI subsystem initialized
[ 0.171003] libata version 3.00 loaded.
[ 0.171314] usbcore: registered new interface driver usbfs
[ 0.171389] usbcore: registered new interface driver hub
[ 0.171582] usbcore: registered new device driver usb
[ 0.172936] tegra-i2c 3160000.i2c: setting prod: prod_c_fm
[ 0.175676] tegra-i2c c240000.i2c: setting prod: prod_c_fm
[ 0.177671] tegra-i2c 3180000.i2c: setting prod: prod_c_fm
[ 0.181878] tegra-i2c 31c0000.i2c: setting prod: prod_c_fm
[ 0.183764] tegra-i2c c250000.i2c: setting prod: prod_c_fm
[ 0.185350] tegra-i2c 31e0000.i2c: setting prod: prod_c_fm
[ 0.188258] max77620 4-003c: CID0: 0x1f
[ 0.188464] max77620 4-003c: CID1: 0x30
[ 0.188638] max77620 4-003c: CID2: 0x00
[ 0.188843] max77620 4-003c: CID3: 0x59
[ 0.189012] max77620 4-003c: CID4: 0x4a
[ 0.189197] max77620 4-003c: CID5: 0x10
[ 0.189391] max77620 4-003c: MAX77620 PMIC OTP Version is 0x4A
[ 0.192663] max77620-sd0: at 1125 mV ; Rail ON
[ 0.193628] max77620-sd1: at 1200 mV ; Rail ON
[ 0.194579] max77620-sd2: at 1800 mV ; Rail ON
[ 0.195462] max77620-sd3: at 3300 mV ; Rail ON
[ 0.196495] max77620-sd4: at 600 mV ; Rail OFF
[ 0.197362] max77620-ldo0: at 1800 mV ; Rail ON
[ 0.199350] max77620-ldo1: at 1800 mV ; Rail ON
[ 0.200060] max77620-ldo2: at 3300 mV ; Rail ON
[ 0.202339] max77620-ldo3: at 1800 mV ; Rail ON
[ 0.203132] max77620-ldo4: at 800 mV ; Rail ON
[ 0.205357] max77620-ldo5: at 1800 mV ; Rail ON
[ 0.206134] max77620-ldo6: at 1800 mV ; Rail ON
[ 0.206893] max77620-ldo7: at 1000 mV ; Rail ON
[ 0.207622] max77620-ldo8: at 800 mV ; Rail OFF
[ 0.208017] gpiochip_add_data: registered GPIOs 1015 to 1023 on device: max20024-gpio
[ 0.210137] max77620-gpio max20024-gpio.0: max77620 gpio successfully initialized
[ 0.211633] max77620 4-003c: max77620 probe successfully
[ 0.211957] media: Linux media interface: v0.10
[ 0.212034] Linux video capture interface: v2.00
[ 0.216477] pps_core: LinuxPPS API ver. 1 registered
[ 0.216487] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <[email protected]>
[ 0.216523] PTP clock support registered
[ 0.216912] Tegra WDT setup timeout = 75 seconds.
[ 0.217450] tegra_wdt_t18x 30c0000.watchdog: tegra_wdt_t18x_probe done
[ 0.220563] arm-smmu 12000000.iommu: found 2 interrupts but expected at least 3
[ 0.220615] arm-smmu 12000000.iommu: probing hardware configuration...
[ 0.220624] arm-smmu 12000000.iommu: SMMUv2 with:
[ 0.220632] arm-smmu 12000000.iommu: stage 1 translation
[ 0.220639] arm-smmu 12000000.iommu: stage 2 translation
[ 0.220645] arm-smmu 12000000.iommu: nested translation
[ 0.220655] arm-smmu 12000000.iommu: stream matching with 128 register groups, mask 0x7f80
[ 0.220665] arm-smmu 12000000.iommu: SMMU address space size (0x800000) differs from mapped region size (0x1000000)!
[ 0.220673] arm-smmu 12000000.iommu: 64 context banks (0 stage-2 only)
[ 0.220681] arm-smmu 12000000.iommu: Stage-1: 39-bit VA -> 48-bit IPA
[ 0.220689] arm-smmu 12000000.iommu: Stage-2: 39-bit IPA -> 48-bit PA
[ 0.230729] arm-smmu 12000000.iommu: registered 66 master devices
[ 0.230745] arm-smmu 12000000.iommu: found only 0 context interrupt(s) but 64 required
[ 0.240380] Advanced Linux Sound Architecture Driver Initialized.
[ 0.241538] vdd-1v8: 1800 mV ; Rail ON
[ 0.241681] vdd-1v8: supplied by vdd-1v8-ddr
[ 0.242003] vdd-rtc: 1100 mV ; Rail ON
[ 0.242043] vdd-rtc: supplied by en-vdd-rtc
[ 0.242391] usb2-vbus-en-5v: 5000 mV ; Rail OFF
[ 0.242432] usb2-vbus-en-5v: supplied by vdd-1v8
[ 0.242710] vdd-qdser: 1100 mV ; Rail ON
[ 0.243043] park-fpd-en: 5000 mV ; Rail ON
[ 0.243315] park-main-cam-en: 5000 mV ; Rail ON
[ 0.253854] mxm-pwr-gpio-2: 5000 mV ; Rail ON
[ 0.264882] mxm-pwr-gpio-3: 5000 mV ; Rail ON
[ 0.264965] mxm-pwr-gpio-3: supplied by mxm-pwr-gpio-2
[ 0.275880] mxm-pwr-gpio-4: 5000 mV ; Rail ON
[ 0.275926] mxm-pwr-gpio-4: supplied by mxm-pwr-gpio-3
[ 0.477044] mxm-pwr_en: 5000 mV ; Rail ON
[ 0.477149] mxm-pwr_en: supplied by mxm-pwr-gpio-4
[ 0.480026] Switched to clocksource arch_sys_counter
[ 0.513993] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 0.514214] nvmap: nvmap_override_cache_ops() set roc flush ops to replace cache ops by set/ways
[ 0.514615] tegra-carveouts tegra-carveouts: vpr :dma coherent mem declare 0x00000000ec500000,195035136
[ 0.514623] nvmap_page_pool_init: Total RAM pages: 933396
[ 0.514628] nvmap_page_pool_init: nvmap page pool size: 116674 pages (455 MB)
[ 0.514698] nvmap_background_zero_thread: PP zeroing thread starting.
[ 0.514999] misc nvmap: created heap vpr base 0x00000000ec500000 size (190464KiB)
[ 0.530721] platform 3530000.xhci: Driver xhci-tegra requests probe deferral
[ 0.531333] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type BCPU-therm
[ 0.531505] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type MCPU-therm
[ 0.531634] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type GPU-therm
[ 0.531798] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type PLL-therm
[ 0.531969] thermal thermal_zone4: Registering thermal zone thermal_zone4 for type AO-therm
[ 0.532261] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type Tdiode_tegra
[ 0.532477] isomgr_init(): iso emc max clk=1600000KHz
[ 0.532483] isomgr_init(): max_iso_bw=23040000KB
[ 0.532905] NET: Registered protocol family 2
[ 0.533759] TCP established hash table entries: 32768 (order: 6, 262144 bytes)
[ 0.534343] TCP bind hash table entries: 32768 (order: 8, 1835008 bytes)
[ 0.535887] TCP: Hash tables configured (established 32768 bind 32768)
[ 0.535976] TCP: reno registered
[ 0.536012] UDP hash table entries: 2048 (order: 6, 262144 bytes)
[ 0.536387] UDP-Lite hash table entries: 2048 (order: 6, 262144 bytes)
[ 0.536854] NET: Registered protocol family 1
[ 0.536900] PCI: CLS 0 bytes, default 64
[ 0.537484] tegra-fuse 3820000.efuse: Fuse driver initialized succesfully
[ 0.556582] host1x 13e10000.host1x: initialized
[ 0.560562] futex hash table entries: 2048 (order: 6, 262144 bytes)
[ 0.560786] audit: initializing netlink subsys (disabled)
[ 0.560880] audit: type=2000 audit(0.543:1): initialized
[ 0.569417] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.569458] msgmni has been set to 7292
[ 0.571862] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
[ 0.571879] io scheduler noop registered (default)
[ 0.571890] io scheduler deadline registered
[ 0.572091] io scheduler cfq registered
[ 0.572388] tegra186-padctl 3520000.pinctrl: padctl mmio start 0x0000000003520000 end 0x0000000003520fff
[ 0.572406] tegra186-padctl 3520000.pinctrl: ao mmio start 0x0000000003540000 end 0x0000000003540fff
[ 0.572472] tegra186-padctl 3520000.pinctrl: FUSE_SKU_USB_CALIB_0 0x2ebc96
[ 0.572480] tegra186-padctl 3520000.pinctrl: FUSE_USB_CALIB_EXT_0 0x9
[ 0.574328] tegra186-padctl 3520000.pinctrl: mailbox is not ready yet
[ 0.574596] platform 3520000.pinctrl: Driver tegra186-padctl requests probe deferral
[ 0.679078] tegra-pcie 10003000.pcie-controller: probing port 0, using 4 lanes and lane map as 0x401
[ 0.679612] Adding domain tsec-pd to PM domain host-pd
[ 0.680150] tegradc 15200000.nvdisplay: Display dc.15200000 registered with id=0
[ 0.680160] DC OR NODE connected to /host1x/sor
[ 0.680164] found /host1x/sor
[ 0.680256] parse_tmds_config: No tmds-config node
[ 0.680319] of_dc_parse_platform_data: could not find vrr-settings node
[ 0.680323] of_dc_parse_platform_data: nvidia,hdmi-vrr-caps not present
[ 0.680327] of_dc_parse_platform_data: could not find SD settings node
[ 0.680331] of_dc_parse_platform_data: could not find cmu node
[ 0.680335] of_dc_parse_platform_data: could not find cmu node for adobeRGB
[ 0.680344] tegradc 15200000.nvdisplay: DT parsed successfully
[ 0.685990] tegradc 15200000.nvdisplay: probed
[ 0.690295] tegradc 15200000.nvdisplay: Allocated 14745856 as FBmem
[ 0.690575] tegradc 15200000.nvdisplay: fb registered
[ 0.693052] tsec 15500000.tsec: initialized
[ 0.694236] tsec 15100000.tsecb: initialized
[ 0.694581] Adding domain nvdec-pd to PM domain host-pd
[ 0.696267] nvdec 15480000.nvdec: initialized
[ 0.696531] Adding domain vic03-pd to PM domain host-pd
[ 0.696547] Adding domain msenc-pd to PM domain host-pd
[ 0.696562] Adding domain nvjpg-pd to PM domain host-pd
[ 0.699596] falcon 15340000.vic: initialized
[ 0.701081] falcon 154c0000.nvenc: initialized
[ 0.702393] falcon 15380000.nvjpg: initialized
[ 0.704355] iommu_context_dev 13e10000.host1x:ctx0: initialized (streamid=56)
[ 0.705680] iommu_context_dev 13e10000.host1x:ctx1: initialized (streamid=57)
[ 0.706444] iommu_context_dev 13e10000.host1x:ctx2: initialized (streamid=58)
[ 0.707216] iommu_context_dev 13e10000.host1x:ctx3: initialized (streamid=59)
[ 0.707915] iommu_context_dev 13e10000.host1x:ctx4: initialized (streamid=60)
[ 0.708680] iommu_context_dev 13e10000.host1x:ctx5: initialized (streamid=61)
[ 0.709436] iommu_context_dev 13e10000.host1x:ctx6: initialized (streamid=62)
[ 0.710200] iommu_context_dev 13e10000.host1x:ctx7: initialized (streamid=63)
[ 0.710491] Adding domain ve-pd to PM domain host-pd
[ 0.713661] nvcsi 150c0000.nvcsi: initialized
[ 0.721780] tegra-adma 2930000.adma: Tegra ADMA driver register 10 channels
[ 0.727271] tegra-gpcdma 2600000.dma: GPC DMA driver register 32 channels
[ 0.731147] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 0.732894] 3110000.serial: ttyS0 at MMIO 0x3110000 (irq = 145, base_baud = 25500000) is a Tegra
[ 0.733676] console [ttyS1] disabled
[ 0.733729] c280000.serial: ttyS1 at MMIO 0xc280000 (irq = 146, base_baud = 25500000) is a Tegra
[ 0.733802] console [ttyS1] enabled
[ 0.733810] bootconsole [uart0] disabled
[ 0.734815] 3100000.serial: ttyTHS0 at MMIO 0x3100000 (irq = 144, base_baud = 0) is a SERIAL_TEGRA
[ 0.735436] 3130000.serial: ttyTHS3 at MMIO 0x3130000 (irq = 147, base_baud = 0) is a SERIAL_TEGRA
[ 0.740598] loop: module loaded
[ 0.740692] nct1008/nct72/tmp451/max6649 0-004c: find device tree node, parsing dt
[ 0.740702] nct1008/nct72/tmp451/max6649 0-004c: starting parse dt
[ 0.740809] nct1008/nct72/tmp451/max6649 0-004c: success parsing dt
[ 0.740921] nct1008/nct72/tmp451/max6649 0-004c: success in enabling nct72 VDD rail
[ 0.814264] nct72: Enabled overheat logging at 106.00C
[ 0.814612] nct1008/nct72/tmp451/max6649 0-004c: nct1008_probe: initialized
[ 0.816515] nct1008/nct72/tmp451/max6649 8-004c: find device tree node, parsing dt
[ 0.816526] nct1008/nct72/tmp451/max6649 8-004c: starting parse dt
[ 0.816541] nct1008/nct72/tmp451/max6649 8-004c: success parsing dt
[ 0.816648] nct1008/nct72/tmp451/max6649 8-004c: success in enabling max6649 VDD rail
[ 0.874575] max6649: Enabled overheat logging at -3.00C
[ 0.874697] nct1008/nct72/tmp451/max6649 8-004c: nct1008_probe: initialized
[ 0.875907] THERMAL EST: found 2 subdevs
[ 0.875917] THERMAL EST num_resources: 0
[ 0.875925] [THERMAL EST subdev 0]
[ 0.875932] [THERMAL EST subdev 1]
[ 0.876304] thermal thermal_zone6: Registering thermal zone thermal_zone6 for type thermal-fan-est
[ 0.876312] THERMAL EST: thz register success.
[ 0.876420] THERMAL EST: end of probe, return err: 0
[ 0.876857] tegra_profiler: Branch: Dev
[ 0.876864] tegra_profiler: Version: 1.108
[ 0.876870] tegra_profiler: Samples version: 36
[ 0.876875] tegra_profiler: IO version: 20
[ 0.876885] armv8_pmu: imp: 0x41, idcode: 0x1
[ 0.876892] armv8_pmu: arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0
[ 0.876899] armv8_pmu: imp: 0x4e, idcode: 0x1
[ 0.876906] armv8_pmu: arch: AA64 PmuV3 NVIDIA (Denver), type: 6, ver: 2
[ 0.876912] armv8_pmu: imp: 0x4e, idcode: 0x1
[ 0.876917] armv8_pmu: arch: AA64 PmuV3 NVIDIA (Denver), type: 6, ver: 2
[ 0.876923] armv8_pmu: imp: 0x41, idcode: 0x1
[ 0.876929] armv8_pmu: arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0
[ 0.876935] armv8_pmu: imp: 0x41, idcode: 0x1
[ 0.876940] armv8_pmu: arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0
[ 0.876946] armv8_pmu: imp: 0x41, idcode: 0x1
[ 0.876951] armv8_pmu: arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0
[ 0.877175] tegra_profiler: auth: init
[ 0.879966] spi-tegra114 3210000.spi: Static pin configuration used
[ 0.882464] tegra-pcie 10003000.pcie-controller: RP prod settings are not found in DT
[ 0.888388] tun: Universal TUN/TAP device driver, 1.6
[ 0.888398] tun: (C) 1999-2004 Max Krasnyansky <[email protected]>
[ 0.888623] vcan: Virtual CAN interface driver
[ 0.888632] qspi_mtd spi6.0: s25fs512s SSG 8 0 1000 4000000
[ 0.888664] qspi_mtd spi6.0: s25fs512s (65536 Kbytes)
[ 0.888677] qspi_mtd spi6.0: mtd .name = spi6.0, .size = 0x4000000 (64MiB) .erasesize = 0x00040000 (256KiB) .numeraseregions = 0
[ 0.888685] CAN device driver interface
[ 0.888748] usbcore: registered new interface driver peak_usb
[ 0.889429] 9 ofpart partitions found on MTD device spi6.0
[ 0.889436] Creating 9 MTD partitions on "spi6.0":
[ 0.889447] 0x000000000000-0x000004000000 : "whole_device"
[ 0.889543] usbcore: registered new interface driver usb-storage
[ 0.890262] 0x000000000000-0x000000080000 : "stuff"
[ 0.891116] 0x0000013c0000-0x000001440000 : "env"
[ 0.891810] 0x000001440000-0x000001480000 : "recovery-linux-dtb"
[ 0.892294] tegra-rtc c2a0000.rtc: rtc core: registered tegra-rtc as rtc0
[ 0.892559] 0x000001480000-0x0000014c0000 : "kernel-a-dtb"
[ 0.892602] i2c /dev entries driver
[ 0.893697] 0x0000014c0000-0x000001500000 : "kernel-b-dtb"
[ 0.894995] 0x000001500000-0x000002000000 : "recovery-linux"
[ 0.896306] 0x000002000000-0x000002f00000 : "kernel-a"
[ 0.897113] 0x000002f00000-0x000003e00000 : "kernel-b"
[ 0.898488] isc-mgr isc-mgr.0: isc_mgr_probeing...
[ 0.899060] isc-mgr isc-mgr.1: isc_mgr_probeing...
[ 0.900218] isc-mgr isc-mgr.2: isc_mgr_probeing...
[ 0.900300] tegra-vi4 15700000.vi: initialized
[ 0.900810] of_graph_get_next_endpoint(): no port node found in /host1x/vi@15700000
[ 0.901195] isc-mgr isc-mgr.3: isc_mgr_probeing...
[ 0.902886] Message RAM Configuration
| base addr |0x0c312000|
| sidfc_flssa |0x00000000|
| xidfc_flesa |0x00000040|
| rxf0c_f0sa |0x000000c0|
| rxf1c_f1sa |0x00000300|
| rxbc_rbsa |0x00000540|
| txefc_efsa |0x00000780|
| txbc_tbsa |0x00000800|
| tmc_tmsa |0x00000c80|
[ 0.903182] Release 3.2.0 from 19.12.2014
[ 0.903605] net can0: mttcan device registered (regs=ffffff8000398000, irq=72)
[ 0.904566] Message RAM Configuration
| base addr |0x0c322000|
[ 0.904821] Release 3.2.0 from 19.12.2014
[ 0.905212] net can1: mttcan device registered (regs=ffffff800039e000, irq=74)
[ 0.905699] max77620-power-off max20024-power-off.4: Event recorder REG_NVERC : 0x0
[ 0.905906] libphy: dwc_phy: probed
[ 0.906289] tegra-pcie 10003000.pcie-controller: PCI host bridge to bus 0000:00
[ 0.906303] pci_bus 0000:00: root bus resource [mem 0x50100000-0x57ffffff]
[ 0.906313] pci_bus 0000:00: root bus resource [mem 0x58000000-0x7fffffff pref]
[ 0.906324] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 0.906332] pci_bus 0000:00: root bus resource [io 0x1000-0xffff]
[ 0.906378] pci 0000:00:01.0: [10de:10e5] type 01 class 0x060400
[ 0.906477] pci 0000:00:01.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.906780] pci 0000:00:01.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 0.906964] pci 0000:01:00.0: [10de:1c36] type 00 class 0x030200
[ 0.906992] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00ffffff]
[ 0.907058] pci 0000:01:00.0: reg 0x14: [mem 0x00000000-0x0fffffff 64bit pref]
[ 0.907081] pci 0000:01:00.0: reg 0x1c: [mem 0x00000000-0x01ffffff 64bit pref]
[ 0.907097] pci 0000:01:00.0: reg 0x24: [io 0x0000-0x007f]
[ 0.907112] pci 0000:01:00.0: reg 0x30: [mem 0x00000000-0x0007ffff pref]
[ 0.908186] device-mapper: ioctl: 4.28.0-ioctl (2014-09-17) initialised: [email protected]
[ 0.909115] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
[ 0.909233] pci 0000:00:01.0: BAR 9: assigned [mem 0x58000000-0x6fffffff 64bit pref]
[ 0.909244] pci 0000:00:01.0: BAR 8: assigned [mem 0x50800000-0x51ffffff]
[ 0.909254] pci 0000:00:01.0: BAR 7: assigned [io 0x1000-0x1fff]
[ 0.909270] pci 0000:01:00.0: BAR 1: assigned [mem 0x60000000-0x6fffffff 64bit pref]
[ 0.909298] pci 0000:01:00.0: BAR 3: assigned [mem 0x58000000-0x59ffffff 64bit pref]
[ 0.909322] pci 0000:01:00.0: BAR 0: assigned [mem 0x51000000-0x51ffffff]
[ 0.909336] pci 0000:01:00.0: BAR 6: assigned [mem 0x50800000-0x5087ffff pref]
[ 0.909345] pci 0000:01:00.0: BAR 5: assigned [io 0x1000-0x107f]
[ 0.909359] pci 0000:00:01.0: PCI bridge to [bus 01]
[ 0.909368] pci 0000:00:01.0: bridge window [io 0x1000-0x1fff]
[ 0.909379] pci 0000:00:01.0: bridge window [mem 0x50800000-0x51ffffff]
[ 0.909388] pci 0000:00:01.0: bridge window [mem 0x58000000-0x6fffffff 64bit pref]
[ 0.909657] pcieport 0000:00:01.0: Signaling PME through PCIe PME interrupt
[ 0.909667] pci 0000:01:00.0: Signaling PME through PCIe PME interrupt
[ 0.909678] pcie_pme 0000:00:01.0:pcie01: service driver pcie_pme loaded
[ 0.909873] aer 0000:00:01.0:pcie02: service driver aer loaded
[ 0.910072] PCI: enabling device 0000:01:00.0 (0000 -> 0003)
[ 0.912372] cpufreq: platform driver Initialization: pass
[ 0.912513] tegra_cluster_clk e090000.cluster_clk_priv: in probe()...
[ 0.912612] tegra_cluster_clk e090000.cluster_clk_priv: passed
[ 0.913271] sdhci: Secure Digital Host Controller Interface driver
[ 0.913276] sdhci: Copyright(c) Pierre Ossman
[ 0.913319] sdhci-pltfm: SDHCI platform and OF driver helper
[ 0.913618] sdhci-tegra 3460000.sdhci: Parent select= pll_p rate=408000000
[ 0.913803] sdhci-tegra 3460000.sdhci: Parent select= pll_c4_out0 rate=196249804
[ 0.913870] tegra-pcie 10003000.pcie-controller: speed change : Gen-1 -> Gen-2
[ 0.913967] sdhci-tegra 3460000.sdhci: Client registration for eMC Successful
[ 0.914102] Adding domain se-pd to PM domain host-pd
[ 0.915758] tegra-se-nvhost 15810000.se: initialized
[ 0.916247] regulator_get() failed for (3460000.sdhci,vddio_sd_slot), -19
[ 0.916252] sdhci-tegra 3460000.sdhci: vddio_sd_slot regulator not found: -19. Assuming vddio_sd_slot is not required.
[ 0.916267] sdhci-tegra 3460000.sdhci: setting min_voltage: 1800000, max_voltage: 1800000
[ 0.916290] tegra-se-nvhost 15810000.se: tegra_se_probe: complete
[ 0.916498] tegra-se-nvhost 15820000.se: initialized
[ 0.916921] tegra-se-nvhost 15820000.se: tegra_se_probe: complete
[ 0.917100] tegra-se-nvhost 15830000.se: initialized
[ 0.917427] tegra-se-nvhost 15830000.se: tegra_se_probe: complete
[ 0.917595] tegra-se-nvhost 15840000.se: initialized
[ 0.918189] tegra-se-nvhost 15840000.se: tegra_se_probe: complete
[ 0.918632] tegra-se-elp 3ad0000.se_elp: tegra_se_elp_probe: complete
[ 0.918716] tegra_bootloader_debug: created tegra_bootloader directory
[ 0.918845] nvadsp 2993000.adsp: in probe()...
[ 0.919459] nvadsp 2993000.adsp: AMC/ARAM initialized.
[ 0.919719] nvadsp 2993000.adsp: nvadsp_app_module_probe
[ 0.920106] kfuse 3830000.kfuse: initialized
[ 0.920385] Denver: backdoor interface is NOT available.
[ 0.922705] tegra186-cam-rtcpu b000000.rtcpu: sce gets unhalted
[ 0.922777] tegra186-cam-rtcpu b000000.rtcpu: booting SCE with Camera RTCPU FW
[ 0.923671] tegra186-cam-rtcpu b000000.rtcpu: enabling tracing
[ 0.923719] tegra186-cam-rtcpu b000000.rtcpu: firmware version cmd=2 ivc=2 sha1 f006d351b9a6e3e1731ef58c6f3070043647086d
[ 0.926271] tegra-camera-rtcpu-character-device ivc-b000000.rtcpu:echo@0: probing /dev/camchar-echo
[ 0.926417] tegra-camera-rtcpu-character-device ivc-b000000.rtcpu:dbg@7c00: probing /dev/camchar-dbg
[ 0.926528] camchar: rtcpu character device driver loaded
[ 0.927639] mmc0: ADMA3 QUIRK2 disabled for sdhci controller
[ 0.927687] sdhci-tegra 3460000.sdhci: No vmmc regulator found
[ 0.927691] sdhci-tegra 3460000.sdhci: No vqmmc regulator found
[ 0.928181] tegra186-aondbg aondbg: aondbg driver probe() OK
[ 0.928378] register_ari_mca_banks: Registered MCA ROC:IOB
[ 0.928455] register_ari_mca_banks: Registered MCA ROC:CCE
[ 0.929139] tegra18_a57_serr_init: on CPU 1 a Denver Core
[ 0.929189] sdhci-tegra 3460000.sdhci: setting min_voltage: 1800000, max_voltage: 1800000
[ 0.929259] parse_throttle_dt_data: Num cap clks = 4
[ 0.929267] parse_throttle_dt_data: clk=mcpu type=1
[ 0.929272] parse_throttle_dt_data: clk=bcpu type=2
[ 0.929279] parse_throttle_dt_data: clk=gpu type=4
[ 0.929284] parse_throttle_dt_data: clk=emc type=3
[ 0.929554] tegra_throttle_probe: probe successful. #cdevs=4
[ 0.952922] coresight-tmc 8030000.etf: TMC initialized
[ 0.953030] mmc0: SDHCI controller on 3460000.sdhci [3460000.sdhci] using ADMA
[ 0.953299] coresight-tpiu 8060000.tpiu: TPIU initialized
[ 0.953624] coresight-funnel 9010000.funnel_bccplex: FUNNEL initialized
[ 0.953853] coresight-funnel 8010000.funnel_major: FUNNEL initialized
[ 0.954163] coresight-replicator 8040000.replicator: REPLICATOR initialized
[ 0.954603] coresight-etm4x 9840000.ptm: ETM 4.0 initialized
[ 0.954993] coresight-etm4x 9940000.ptm: ETM 4.0 initialized
[ 0.955411] coresight-etm4x 9a40000.ptm: ETM 4.0 initialized
[ 0.955819] coresight-etm4x 9b40000.ptm: ETM 4.0 initialized
[ 0.964237] sdhci-tegra 3460000.sdhci: setting min_voltage: 1800000, max_voltage: 1800000
[ 0.964288] tegra186-ahc 290b900.ahc: ahc platform probe started
[ 0.964384] tegra186-ahc 290b900.ahc: ahc platform probe successful
[ 0.964542] OPE platform probe
[ 0.964656] OPE platform probe successful
[ 0.966787] GACT probability NOT on
[ 0.966796] Mirror/redirect action on
[ 0.966806] u32 classifier
[ 0.966808] Actions configured
[ 0.966819] Netfilter messages via NETLINK v0.30.
[ 0.966856] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[ 0.967304] xt_time: kernel timezone is -0000
[ 0.967448] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 0.967528] arp_tables: (C) 2002 David S. Miller
[ 0.967556] TCP: cubic registered
[ 0.967563] NET: Registered protocol family 17
[ 0.967576] NET: Registered protocol family 15
[ 0.967582] can: controller area network core (rev 20120528 abi 9)
[ 0.967616] NET: Registered protocol family 29
[ 0.967637] can: raw protocol (rev 20120528)
[ 0.967643] can: broadcast manager protocol (rev 20120528 t)
[ 0.967652] can: netlink gateway (rev 20130117) max_hops=1
[ 0.967737] 8021q: 802.1Q VLAN Support v1.8
[ 0.971071] tegra186-dpaux-pinctrl 15040000.dpaux: initialized
[ 0.971821] Adding domain ispa-pd to PM domain host-pd
[ 0.972853] isp 15600000.isp: initialized
[ 0.973838] xhci-tegra 3530000.xhci: can't get usb3-0 phy (-517)
[ 0.974007] platform 3530000.xhci: Driver xhci-tegra requests probe deferral
[ 0.974244] tegra186-padctl 3520000.pinctrl: padctl mmio start 0x0000000003520000 end 0x0000000003520fff
[ 0.974256] tegra186-padctl 3520000.pinctrl: ao mmio start 0x0000000003540000 end 0x0000000003540fff
[ 0.974297] tegra186-padctl 3520000.pinctrl: FUSE_SKU_USB_CALIB_0 0x2ebc96
[ 0.974303] tegra186-padctl 3520000.pinctrl: FUSE_USB_CALIB_EXT_0 0x9
[ 0.975352] xhci-tegra 3530000.xhci: No UTMI port has OTG_CAP
[ 0.975360] xhci-tegra 3530000.xhci: No USB3 port has OTG_CAP
[ 0.976538] xhci-tegra 3530000.xhci: Direct firmware load for tegra18x_xusb_firmware failed with error -2
[ 0.976549] xhci-tegra 3530000.xhci: cannot find firmware....retry after 1 second
[ 0.978184] eqos 2490000.ether_qos: Setting local MAC: 0 4 4b 52 f9 7
[ 0.996249] sdhci-tegra 3460000.sdhci: setting min_voltage: 1800000, max_voltage: 1800000
[ 1.000402] bpmp: mounted debugfs mirror
[ 1.000530] [dram-timers] DRAM derating cdev registered.
[ 1.004867] max77620-ldo7: disabling
[ 1.004875] max77620-ldo6: disabling
[ 1.004879] max77620-ldo4: disabling
[ 1.004882] max77620-ldo2: disabling
[ 1.004886] max77620-ldo0: disabling
[ 1.004890] max77620-sd3: disabling
[ 1.004893] max77620-sd2: disabling
[ 1.004896] max77620-sd1: disabling
[ 1.004898] max77620-sd0: disabling
[ 1.008347] ALSA device list:
[ 1.008352] No soundcards found.
[ 1.036313] tegra186-snd-p2382 sound_ref: ADMAIF1 <-> ADMAIF1 mapping ok
[ 1.036408] tegra186-snd-p2382 sound_ref: ADMAIF2 <-> ADMAIF2 mapping ok
[ 1.036507] tegra186-snd-p2382 sound_ref: ADMAIF3 <-> ADMAIF3 mapping ok
[ 1.036594] tegra186-snd-p2382 sound_ref: ADMAIF4 <-> ADMAIF4 mapping ok
[ 1.036680] tegra186-snd-p2382 sound_ref: ADMAIF5 <-> ADMAIF5 mapping ok
[ 1.036771] tegra186-snd-p2382 sound_ref: ADMAIF6 <-> ADMAIF6 mapping ok
[ 1.036859] tegra186-snd-p2382 sound_ref: ADMAIF7 <-> ADMAIF7 mapping ok
[ 1.036947] tegra186-snd-p2382 sound_ref: ADMAIF8 <-> ADMAIF8 mapping ok
[ 1.037057] tegra186-snd-p2382 sound_ref: ADMAIF9 <-> ADMAIF9 mapping ok
[ 1.037147] tegra186-snd-p2382 sound_ref: ADMAIF10 <-> ADMAIF10 mapping ok
[ 1.037238] tegra186-snd-p2382 sound_ref: ADMAIF11 <-> ADMAIF11 mapping ok
[ 1.037331] tegra186-snd-p2382 sound_ref: ADMAIF12 <-> ADMAIF12 mapping ok
[ 1.037422] tegra186-snd-p2382 sound_ref: ADMAIF13 <-> ADMAIF13 mapping ok
[ 1.037510] tegra186-snd-p2382 sound_ref: ADMAIF14 <-> ADMAIF14 mapping ok
[ 1.037602] tegra186-snd-p2382 sound_ref: ADMAIF15 <-> ADMAIF15 mapping ok
[ 1.037690] tegra186-snd-p2382 sound_ref: ADMAIF16 <-> ADMAIF16 mapping ok
[ 1.037782] tegra186-snd-p2382 sound_ref: ADMAIF17 <-> ADMAIF17 mapping ok
[ 1.037872] tegra186-snd-p2382 sound_ref: ADMAIF18 <-> ADMAIF18 mapping ok
[ 1.037963] tegra186-snd-p2382 sound_ref: ADMAIF19 <-> ADMAIF19 mapping ok
[ 1.038071] tegra186-snd-p2382 sound_ref: ADMAIF20 <-> ADMAIF20 mapping ok
[ 1.060351] Waiting for root device /dev/mmcblk0p2...
[ 1.076556] mmc0: BKOPS_EN bit is not set
[ 1.077245] sdhci-tegra 3460000.sdhci: setting min_voltage: 1800000, max_voltage: 1800000
[ 1.102950] mmc0: tap value and tuning window after hw tuning completion ...
[ 1.102965] mmc0: tuning_window[0]: 0xffffffff
[ 1.102971] mmc0: tuning_window[1]: 0xfffff8ff
[ 1.102977] mmc0: tuning_window[2]: 0xff1fffff
[ 1.102982] mmc0: tuning_window[3]: 0xffffffff
[ 1.102988] mmc0: tuning_window[4]: 0xfffffff1
[ 1.102993] mmc0: tuning_window[5]: 0xffff1fff
[ 1.102998] mmc0: tuning_window[6]: 0xf1ffffff
[ 1.103004] mmc0: tuning_window[7]: 0x7fffffff
[ 1.103008] sdhci: Tap value: 63 | Trim value: 5
[ 1.103035] sdhci: SDMMC_VENDOR_INTR_STATUS[0x108]: 0x40000
[ 1.108635] mmc0: new HS400 MMC card at address 0001
[ 1.108974] mmcblk0: mmc0:0001 032G34 29.1 GiB
[ 1.109094] mmcblk0boot0: mmc0:0001 032G34 partition 1 8.00 MiB
[ 1.109187] mmcblk0boot1: mmc0:0001 032G34 partition 2 8.00 MiB
[ 1.109274] mmcblk0rpmb: mmc0:0001 032G34 partition 3 4.00 MiB
[ 1.112294] mmcblk0: p1 p2 p3
[ 1.163838] VFS: Mounted root (squashfs filesystem) readonly on device 179:2.
[ 1.164818] devtmpfs: mounted
[ 1.165460] Freeing unused kernel memory: 1928K (ffffffc000ca7000 - ffffffc000e89000)
[ 1.165477] Freeing alternatives memory: 36K (ffffffc000e89000 - ffffffc000e92000)
[ 1.345483] runit/1 starting
[ 1.906757] random: pvs urandom read with 30 bits of entropy available
[ 1.982235] xhci-tegra 3530000.xhci: Firmware timestamp: 2016-09-01 11:32:41 UTC, Version: 55.05 release
[ 1.984049] xhci-tegra 3530000.xhci: xHCI Host Controller
[ 1.984069] xhci-tegra 3530000.xhci: new USB bus registered, assigned bus number 1
[ 1.984939] xhci-tegra 3530000.xhci: irq 195, io mem 0x03530000
[ 1.985468] hub 1-0:1.0: USB hub found
[ 1.985496] hub 1-0:1.0: 4 ports detected
[ 1.985858] xhci-tegra 3530000.xhci: xHCI Host Controller
[ 1.985872] xhci-tegra 3530000.xhci: new USB bus registered, assigned bus number 2
[ 1.986304] hub 2-0:1.0: USB hub found
[ 1.986329] hub 2-0:1.0: 3 ports detected
[ 2.062131] EXT4-fs (dm-0): mounted filesystem with ordered data mode. Opts: (null)
[ 2.071075] EXT4-fs (dm-1): mounted filesystem with ordered data mode. Opts: (null)
[ 2.072843] EXT4-fs (dm-2): mounted filesystem with ordered data mode. Opts: (null)
[ 2.074875] EXT4-fs (dm-3): mounted filesystem with ordered data mode. Opts: (null)
[ 2.076662] EXT4-fs (dm-4): mounted filesystem with ordered data mode. Opts: (null)
[ 2.092849] lockdown: I smell a wumpus. Locking the doors and windows.
[ 2.314077] eqos 2490000.ether_qos eth0: Link is Up - 1Gbps/Full - flow control off
[ 2.587201] xhci-tegra 3530000.xhci: entering ELPG
[ 2.600362] xhci-tegra 3530000.xhci: entering ELPG done
[ 2.759867] Boot count set to 2053
[ 4.267717] run (2713): /proc/2713/oom_adj is deprecated, please use /proc/2713/oom_score_adj instead.
[ 4.333304] Pascal temp is ok (43)
[ 6.137847] watchdog watchdog0: wdt timeout set to 1 seconds
[ 6.237556] random: nonblocking pool is initialized
[ 12.173604] tegra-i2c c250000.i2c: no acknowledge from address 0x30
[ 12.173670] tegra-i2c c250000.i2c: setting prod: prod_c_fm
