JonDarian
Thanks for the tip. I did find the technique with the right scroll wheel, but still found the following distance would be really variable. Sometimes it would be a comfortable distance, sometimes my wife would be pushing her foot through the floor as she applied the imaginary brakes on her side of the car.The TACC following distance is configurable - it's in one of the menus (Driving or Autopilot I think) but the easiest way to change it is to push left/right on the right-hand side control thingy on the wheel (the same one that adjusts the TACC speed when it's active, though you can adjust the follow distance any time). I always suggest people set it to at least 4 or 5, you get a lot less sudden braking for potential obstacles as well.
Thanks again.Yes, the scheduled departure/off-peak charging is best suited for a wall charger. I use that function all the time, but can charge at 11kW so it never takes more than a few hours of charging in one session.
For charging from solar though, I wouldn't use scheduled departure - I'd use scheduled charge, and tell it to start at 9am (or whatever time of day your solar is reliably putting out more than your UMC can consume). You may have to remember to hit 'Stop Charging' when the light starts to fade if it hasn't completed yet, though.
I may end up getting a wall charger at some point, but will see how we go living with the UMC for a while. I do wish I could just set start and end points for charging, and override them on occassions when I want to fully charge now.
Just a reminder to Queenslanders: Ergon and Energex currently restrict you to 20A per phase unless you are on a controlled tariff (which the network can turn off for up to 6 hours/day). This might mean that to directly offset your consumption against your solar PV production (net metering), you may be limited to 20A. On a single-phase house, the wall charger can only deliver 4.8kW (20A x 240V) on a continuous tariff. Three-phase connections are more expensive to install, but allow the wall-charger to charge at up to 11kW. It is worth checking how your installation will work before buying your hardware.
