Since MPP already had excellent instruction for this product, I will only highlight insights that I learn from my installation.
These are the torque Spec per Tesla service manual.
Knuckle nut - 180NM, 132lb/ft
Lateral link/Spherical bearing - 106NM, 78lb/ft (MPP instruction called for 95-100lb/ft)
Struct to arm - 106NM, 78lb/ft (compress suspension to normal riding height before torquing this to spec)
Special Tools
22mm, 21mm, 19mm box wrench, T45 torx, 12-ton hydraulic press.
I break torque on all the bolts first, before removing any bolts/nuts. Keeping the suspension intact provides the rigidity necessary to break toque. Then I disconnect the strut from the lower arm. The next to go are the two bolts holding the lateral link in place. Last is the nut on the knuckle. The sequence for installation is reversed.
About a tablespoon of water dripping down from behind this bolt during the removal process.
The bolts have some surface rust and corrosion, a quick metal wire bush cleans it right up. On further inspection, the rust and corrosion appear to be coming from the subframe. I'm in Northern California which doesn't get a lot of rain. I wonder that it will be like for cars in places where there are lots of rain and salt. I use Loctite 242 on pretty much all the bolts/nuts.
Here is a look into the subframe. Yep, green stuff in there.
