After I took out the stock stud and test-fit the ARP. It was immediately apparent that the ARP studs will not work. The shoulder diameter before the knurl section is too big to fit the stock hub. The shoulder on the Dorman studs is comparable to stock studs. I would love to install the ARP, but it will require reaming the hole to a slightly larger diameter. ROI is just not worth it.
Looking through the hub hole from the front side. You can see the marks left by the stock knurl.
A view from the backside. The caliper side of the hub is the best place to insert the new studs, plenty of clearance for long studs.
Length comparison between stock and ARP studs.
The nifty Lisle 22800 wheel stud installer tool. Money well spent. You might have noticed that I didn't remove the brake rotor. There is not a mechanical reason for removing it unless it is in the way of removing or inserting the studs. Maybe if you are not careful with the hammer? Having the brakes intact can speed up the process, as you will see in the next step.
With a ratchet wrench, I was able to tighten/pull in the stud into the hub almost all the way. Only the last 1/2 to one turn is accomplished with a torque wrench, which I torque it to 175NM / 129lb/ft.
I didn't have a helper today. If I had a helper, or remember to use a stick to jam on the brake pedal, I would not need to use a wrench to hold the rotor/hub in place while I torque down the studs.
