What are you going with? AP? 6 piston RB?
That's a good choice, anti knockback springs, thick enduro pads and you can even spec it with a larger rotor, I believe. Do you plan to remove glass roof and exchange the interior for a roll cage?RB is excellent for street/track. I'm going with the full track - AP Competition.
UPS delivered these today. ARP 100-7736 wheel studs. This is a convenience and safety upgrade from stock. The bullet nose end makes it wheel change much easier. The extra length will allow for full engagement of the lug nut.
When bedding brakes on our cars how do you handle the regen braking force? Do you change it to low regen, or put it in N before hitting the brake pedal, or something different? I have a DM non-p, so no track mode.A good video from Essex about bedding procedure with lots of nuance information. Skip to 12:30 mark to watch bedding of street pad in action.
Please install it and let us know that it fits. I liked those studs on my race car - it was convenient. Are your nuts not sitting full on the stud?
Thanks. I’ll do it that way.Switch to Low Regen when you bed the brakes. Then switch back to standard regen on the cool down drive to avoid using the brakes at all.
I have Titan7's OWL titanium lugs, it is much deeper lug than stock. With it fully torqued to spec, I still have 12.3mm of lug threads left. The bullet nose will make the wheel change a lot easier, especially at the end of track day when I'm exhausted.
Stock is 1.75" below the head. These are 2.7" below the head. So almost one inch longer than stock, with 0.4" being the bullet nose, and about 0.6" of additional threads.Very nice! Any idea how many mm of threads these will add over stock?
Here is the information on the weight.
Arms (saving)
Stock / MPP
- Spring arm - 2880g / 1724g (1156g)
- Rear fore upper arm - 788g / 632g (156g)
- Rear fore lower arm - 948g / 798g (150g)
I didn't measure the toe or camber arms. They were installed in 2019.
Spring Setup (per side)
Stock+rubber isolator / MPP AWD Sports+rubber isolator+height adjuster / New Spring+height adjuster
- 3462g / 3904g / 2336g (vs stock 1126g / vs MPP sports coil 1568g)
Total savings of 6060g off the rear. For those insisting on using the imperial unit, please multiply by 2.2.
