cwerdna
I'm confused, was the charging rate 26 kW or were 26 kWh dispensed. "station that is capable of 50 KWh" makes no sense. Are you talking about a charging rate of 50 kW or what the charger is rated at or you had 50 kWh of energy dispensed?I have the Chademo franken-adapter. I could only get 26 KWh out of a station that is capable of 50 KWh on my last couple attempts.
Do you have a Plugshare link to the CHAdeMO charger(s) you've used?
kW and kWh are very different metrics. Please see Near Turtle to cells balanced: 20.8 kW with 2015 Leaf with 24 kW battery: Low kW? As expected? Battery losing capacity? - My Nissan Leaf Forum.
You had no idea what you were talking about at Model 3 to have <60kW Supercharging? and frustrated almost everyone who participated there.
Wws is correct. Some "50 kW" chargers are rated at some stupid voltage (but really can't get higher than 100 amps). 100 amps * 500 volts = 50,000 watts = 50 kW. Problem is, no EVs that I know of have 500 volt packs. So, let's say the voltage is 370 volts * 100 amps = 37,000 watts = 37 kW.
For example, Watch a Bolt EV at a ChargePoint Express 250 charge at up to 55 kW "The Express 250 charger, capable of up to 62.5 kW of DC output at up to 156A and 1,000V, is installed near the loading dock at ChargePoint’s headquarters in Campbell, California as".
I've used that exact DC FC (SAE Combo side, of course) at that location and that unit # (41) on my Bolt and have hit 55 kW when below about 55% SoC. After, it ramps down, just like in the video. It is capable of a high enough amperage at the voltages the Bolt and most EVs use for charging, which is why it can get above 50 kW. Multiply the voltage * amps at a given point in the video to get watts then / by 1000 to get kW.
