Bert’s Media Player 8.0 2.42.40 Observations & Workarounds
I updated from 2.36.108 to 2.42.40 upon receipt this morning, and spent several more hours trying to identify what is going on with the “new” Media Player. Consider this a delta update to my last couple of long upstream posts, with the same caveats.
- SORT ORDER IS HORRIBLY PROBLEMATIC (yes, I’m screaming!) if you use all parts of the interface and think about this design from a real music-owner’s POV, not just a technical one
- Note: If you are looking for items that start with a number, they are after alpha characters. OK, so be that.
- The greater challenge for me is the inconsistent secondary sort depending upon what view you use, and how it many times just isn't presenting tracks they way you want to play them. Some of this has changed from 2.36.108, and not all for the better. After hours of trying to figure this out, here’s what I believe 2.42.40 is doing as you drill down to individual tracks being displayed using each Media Player USB view:
- Songs
- Alphanumeric list by TRACKTITLE (track title tag). Good
- An enhancement would be to then sort this list secondarily by ALBUM (title)+ALBUMARTIST so any duplicate track titles are in sequence by album. Not a biggie IMHO, but a nice to have.
- Artists
- Alphanumeric list by TRACKARTIST. Good.
- Alphanumeric list by ALBUM (title). Good.
- Tracks are then displayed alphanumerically by FILENAME. BUG!
- This should be DISCNUMBER+TRACKNUMBER so your tracks are shown and played in correct sequence. Period.
- Albums with the same ALBUM (title) and even different ALBUMARTIST across the USB device are being merged into a single album within the interface. BUG!
- Albums
- Genre
- Alphanumeric list by GENRE. Good.
- Tracks are then displayed alphanumerically by TRACKTITLE (track title rag).
- From a usability perspective, I frankly see this as a BUG, not a requested enhancement, but I agree the point could be debated. IMHO, the TRACKTITLEs within a genre should be presented in ALBUMTITLE+DISCNUMBER+TRACKNUMBER sequence to make any real sense out of this long list.
- Folder
- Note: Within Folder View, subdirectory folders are sorted alphabetically and in-line with tracks. A great enhancement would be for Tesla to move Folders to the top of the list like all other browsers and players do.
- Alphanumeric list by Folder Name. Good.
- Further drill down are also alphanumeric lists by Folder Name until you reach the lowest level directory containing tracks. Good.
- Tracks are then displayed alphanumerically by TRACKTITLE. That’s a BUG at least from my POV!
- IMHO, since Folder View is by it’s very nature, a RYO environment, Tesla should not mix use of directory names and tag data as they are. Instead tracks should be sorted alphanumerically by DIRECTORY and FILENAME, and don’t use tag data for sorting anywhere within Folder View.
Sorry, but it’s no bloody wonder why it’s become even harder to follow posts about some people seeing things working right, when others do not. The order tracks are now presented is pretty well mixed-up between tags and physical filenames across the interface -- from at least my perspective as someone that has worn both a programming hat, and who owns a large music library he listens to for hours each and every day.
First of all, I want to commend BertL for all his work to investigate the effect of the latest release on USB functionality, and for the detailed write-up.
But I have to disagree with the OP's findings on certain points. I installed 2.42.40 yesterday and had a few minutes to test with my USB memory stick this morning.
Playing by Artist/Album -- Contrary to the OP, I found that the tracks play in track order, not alphabetical.
Playing by Album -- Again, I find the tracks play by track order.
Playing by Songs or Genre or Folder -- I agree that the order of songs is alphabetical by song title.
I do not know what the reason is for the difference in my findings versus BertL's. One reason might be that most of my music was ripped from CDs using software such as Roxio Burn. I did not start from an iTunes library as he did. (I do have some songs from my spouse's iTunes library, but I have not done enough testing to see if they behave differently.)
Looking at my tag data, I see that virtually all my tracks have the track number in the file name. That may explain why they play in order -- perhaps Tesla is using Filename as the sorting key when playing by artist or album. And it may be that I added the track number to the file name when I created the music library for the Tesla. I seem to recall that was recommended in the past -- but I have lost track of whether I did that myself or not. In any case, that
may be why the songs play in track order in the Artist or Album mode.
Unfortunately, the sort order for Genre has changed from the initial release of version 8.0. Originally, the Genre sort order was by track number, but that has now been lost. (Which annoys me because I went to a fair amount of effort to create some additional genres to leverage that sort order for certain albums!) But now it appears that you can play an album in the correct order starting from Folder or Artist or Album, so starting from Genre is not needed.
There was one exception to my findings. I have one album that played in correct order when starting from Folder/Artist/Album. That particular album has the track number in the Track Title tag -- it is the only one in my collection that does, and I do not recall why it does. Probably just an artifact for how I did the data entry for that album (which, if I recall correctly, I had to do manually). And this is what BertL does with his workaround method posted above -- He adds Disc number and Track number to the Track Title tag. Which I agree is now the key to playing tracks in proper order when starting from Songs, Genre, or Folder, but apparently is not currently necessary to play from Artist or Album. So for my own sake, I hope that Tesla does not start using Track Title for all sorts, because then I would have to modify all my track title tags!
By the way, in all my comments I am ignoring disc number, because I have few if any multi-disc sets, so I do not know how they would work except for what the OP has written above. If I can find a suitable album to test that detail, I will.
