Thekiwi
It seems like you're arguing with nobody. No one is disagreeing that the vast majority of people who contract it will be fine.
In related news: on average 5 out of every 6 people who play Russian roulette will be fine.
Getting a bit OT for this thread, so I'll try to be brief: Iceland has a company named deCODE Genetics, which was designed around doing whole-population genetic studies for disease modeling, so the company has been repurposed into doing randomized sampling of the population to look for COVID-19 in people who are not suspect cases - just the general public. They found the disease in around 1% of the general population over a period of a couple weeks (reported 1 week ago) - an implied per-capita rate twentyfold that of the country's official diagnoses at the time of reporting (which in turn has involved one of the most aggressive testing regimes in the world). Over half had no symptoms whatsoever, and the rest, generally just a minor cold.
In an experiment which started several weeks ago, Italy tested the entire town of Vò in a series of rounds and successfully eradicated the disease from the town. Again, this is one of the few cases of experiments of testing of the general population rather than suspect cases. 3% of the population was determined as infected during the first round. 50-75% of them were entirely asymptomatic. Most of the rest had only minor cold symptoms and did not suspect that they had the disease. During the study, asymptomatic cases usually remained asymptomatic, and most minor cases remained minor.
The net picture is that the disease was already widespread even several weeks ago; that people with no symptoms whatsoever are the majority; and of those with symptoms, symptoms so minor that people don't get tested are by far the most common. To match with the death rate (as severe cases almost always get tested), a widespread disease in the population implies a low IFR (infection fatality rate), and implies that places with overloaded medical systems are overloaded not because the disease sends a large percent of its victims to the hospital, but because a large percent of the population has already gotten infected. This implies that the disease will tend to play itself out sooner.
As mentioned, the other study I mentioned (still preliminary) estimated that Wuhan hit a 19% infection rate at its peak, and that the disease had a non-time-delay IFR of 0,04% and a time-delay IFR of 0,12%. They also found (as others have) that the disease is highly prone to nosocomical transmission (spread inside hospitals and clinics, generally by staff) - that is to say, prone to spread to the most vulnerable of patients. I.e. that stamping out nosocomical transmission is one of the most important steps that can be done. Both Wuhan and Lombardy had extensive problems with nosocomical transmission before the severity of the situation was realized.
ED: Well, so much for trying to be brief...
Depends on whether or not you use a Glock I suppose...In related news: on average 5 out of every 6 people who play Russian roulette will be fine.
How about portable, battery-powered masks that purify air with arrays of high-intensity UV leds or ceramic heating elements [cost next to nothing]?
A Medical Worker Describes Terrifying Lung Failure From COVID-19 — Even in His Young Patients | March 21
... “It first struck me how different it was when I saw my first coronavirus patient go bad. I was like, Holy *sugar*, this is not the flu. Watching this relatively young guy, gasping for air, pink frothy secretions coming out of his tube.” ...
A Medical Worker Describes Terrifying Lung Failure From COVID-19 — Even in His Young Patients — ProPublica
But, I'd much rather design a 3D printable (at least the enclosure part of it) battery-powered air purifier mask that used UV-C LEDs. The part that worries me is there wouldn't be enough time element for the air purifier to purify the air.
Are we confident that Florida is even bothering to test and report its cases...It seems to have huge discrepancey between expected cases and reported cases...
I don't know the intensity required to reliably kill off CV. Yes, it may turn out to be a brain fart. If it's very high and needed a lot of power, I was thinking there could be a switch/proximity sensor that triggered the well-shielded UV lights. Might require a spiral chamber and radial pump? [Those two go well together!]
Alternatively, ceramic heaters are dirt cheap.
https://www.alibaba.com/product-det...?spm=a2700.details.deiletai6.8.19bb2d01EvxzRz
It's past midnight here, so I'll be curious to know what you dug up!
Hospitalization for any cause, or something else ?Other item I'm tracking is hospitalizations.....it's over a 1,000
Does anyone know if Florida is performing tests? Or are they choosing to not test in order to suppress the number of case?Operations Dashboard for ArcGIS 25,493 US
US is #3 according to that site. cases are picking up. i'm guessing a product of the testing ramp.
Strangely Illinois and Michigan are showing more cases than Florida. I find that highly suspect or maybe Florida is due for an update?
Texas starting to add to the count as well.
this site has Florida up to 764, but still lower than Michigan. Maybe Florida testing hasn't caught up?Does anyone know if Florida is performing tests? Or are they choosing to not test in order to suppress the number of case?
To a degree testing suppression, but mostly they are affected by the brain-dead trump plan that delayed volume test production by a couple of months.Does anyone know if Florida is performing tests? Or are they choosing to not test in order to suppress the number of case?
#New Orleans
Well, that was terrifying. Thanks. I already knew I really didn't want it, being a fit 42 year old. Now I really really don't want it.
Medtronics did an inversion and nominally is now an Irish company. IIRC they have a number of factories around the world including Minneapolis, Boston, Memphis, Ireland, and China.IIRC, Medtronics ventilator mfg is in Ireland? Medtronics requested we not shutter our doors. Ditto for other medical device companies. Every day we don't work, adds one day to the release of all the medical devices we are working on.
Elon Musk: Should Have 1000 Ventilators Next Week, + 250,000 N95 Masks For Hospitals Tomorrow — CleanTechnica Exclusive | CleanTechnica
That's a lot of masks to just have lying around, isn't it?
