tslas
It could be the vampire charge, but 10 miles is pretty significant if your car finishes charging from a scheduled charge at 3:30 am. Perhaps the car didn't charge this morning? Tesla can tell you if you work with the service center, but it might be something you wait to determine until later.
Have you checked your charging level slider to determine whether it was accidentally set lower? Perhaps try a range charge to 100% to see where it ends up, if it seems to be set to the right amount?
A call to the service center would allow them to pull logs and look to see if there's a problem after you try those steps.
Thanks, I contacted Tesla and Service center is pulling the Logs and looking at it.
I verified that the charge limit was set to 90%.
Hopefully, it is just that the Scheduled charging didn't start.
Otherwise Range Loss and Vampire Drain will make it a larger problem.
