dirkhh
Middle-aged Member
I'm getting 200-201 on full charges after 18k miles in my 60.
Funny, that's pretty much exactly the same here. 18k miles (in 12.5 months) and 202 on my last range charge (during my trip to TMC Connect).
^ lots of deep cycling?
Actually, no. I do most miles with lots of shallow cycling. My daily commute 75-100 miles, but I usually charge both at home and work, so typically 35 to 50 miles per cycle twice a day. However, I do deep cycle from full range charge to near empty at least once every month or two months. Did a lot of traveling and range charges during July. During the summer months I have started setting the charge slider down to about 80% most of the time (winter always 90%). After doing this for a while it will bring the max rated range down to about 205ish. I have long ago found I can restore some range buy letting the battery spend a cool night on a range charge. If I do that a couple of times it will bring the range back up to at least 208. If I range charge to completion on a supercharger, it's really effective at restoring range. It's not just temporary either, I did more range charges on a cold battery from a 90% charge and it still went right up 209 rated miles. (see pic below)View attachment 56167
After a year of never seeing more than 262 miles rated after a Range Charge, I was charged at the Service Center last week and the car showed 272 Rated when I picked it up...go figure.
that is amazing... seems like there's a story behind that change considering it happened at the service center... any ideas?After a year of never seeing more than 262 miles rated after a Range Charge, I was charged at the Service Center last week and the car showed 272 Rated when I picked it up...go figure.
How is that even possible? I though 265 miles was the top Rated miles for a Range Charge.
When mine was new, I could get 263 to 265 Rated miles, but now I'm at about 240 if I'm lucky (32,000 miles / 15 months).
I'm at 25k and 18 months and I think it was 252 last time I range charged. I suppose that about within expectation if I should expect 80% capacity after 100,000 miles.When mine was new, I could get 263 to 265 Rated miles, but now I'm at about 240 if I'm lucky (32,000 miles / 15 months).
I have 11,550 miles on my 60 Kwh Model S. Purchased in Feb 2014. The rated range charge in miles has decreased from 209 to 184. The biggest drop (206-194) came after the 5.9 firmware update. Tesla service cannot explain.
Leaving you pack overnight with a range charge is a very bad idea. Never do this. When you need to range charge time it so the charge finishes when you leave. About the worst thing you can do to a pack is leave it fully charged.
