Wiki Everything you wanted to know about Intelligent Octopus But Were Afraid To Ask
Why write this post?
A lot of people are starting to get interested in IO. I don't think Octopus do a very good job of spelling out the benefits in their website. They have some FAQs, but the same questions keep coming up over and over on the forums.
What is it?
In a nutshell, IO is a split tariff that gives you a cheap off-peak rate for charging your EV and other electrical items in the household, including home batteries.
Isn’t that the same as Octopus Go or Go Faster?
The principle is the same, but in exchange for some benefits which we’ll explain, you allow Octopus to control the timing of your EV charge, so they can choose low carbon intensity and/or cheap wholesale priced time slots.
So I’m not in control of my charge? I don’t like the sound of that!
Well yes…and no. You’re in control of how much to charge and when you want the car to be ready, just like you would be normally. Within those parameters, you’re allowing Octopus to control which half-hour slots the car chooses to get to that target % charge. And you can always override IO if you want to “bump charge” through the day.
OK, but what are the benefits you mentioned for this trade off?
First of all, you get a larger guaranteed off-peak window for using household appliances and charging home batteries, etc. It’s six hours between 23:30-05:30. Go, for example, is a fixed 4 hour window.
In addition, when IO schedules your EV charging slots it sometimes creates schedules that fall outside of the fixed, six hour window. If that happens your EV charging and all your household use in these extra-slots is also charged at off-peak rates.
I have frequently had schedules give me seven or more hours of off-peak rates. On one occasion, I had a total of ten hours of off-peak rates.
Am I eligible?
You need a smart meter and a compatible car and/or charger. Since you’re reading this here, I assume you’ve got or are thinking of getting a Tesla. IO works with the Tesla API to create the charging schedules. The advantage of this is that IO will work with any* home charger. If you have a charger with smart features, you need to disable them so that the charger acts as a dumb switch. IO will control everything via Tesla’s API to start and stop your charging.
*Even your granny charger - but you need to tell IO what the max throughput is when you go through setup so that it can work out your schedules properly.
Some of this sounds too good to be true.
Phantom drain caused by having smart charging enabled in the Octopus app has been fixed as of 30th August 2022. One small side effect appears to be that schedules sometimes take longer to appear in the app after plugging in.
Further questions (to be updated in the main thread body once the edit timer on this post expires)
I have two EVs, can I charge the other while on IO?
Not with IO scheduling the charging, but you can charge any other car in the fixed 23:30-05:30 off peak window or at any other time at peak prices.
What are the rates etc?
Octopus do a decent job of explaining the peak and off-peak rates along with contracts etc. Head over to their pages to discover that.
I asked for a target % of x, but I got less than x.
There are two or three reasons for this.
The first, most common reason, is that Tesla reports battery % differently depending on where you look. The API (that IO uses) reports the gross battery %. This is generally fixed but can fluctuate very slightly. The Tesla app shows usable %. Apps like Teslamate and Teslafi can display both. Quite often, there is a delta of 2-3% which may be down to battery temp or other factors. This usable % will often be recovered as the battery warms up during a drive.
Some users have reported charging % being way off, perhaps 10% or more. This could be down to an error in the onboarding process. Some of the charger database entries incorrectly assume the charger you are onboarding is the 11kW version, without actually saying so in the charger description. The Andersen A2 was an early example of this. If you suspect this may be the case, the easiest thing to do is go through the on-boarding again and choose "Generic 7.4kW charger". It won't affect your functionality on IO in any way.
Lastly, it has to be mentioned that occasionally IO just craps out. It may be down to a comms error, a server error at Octopus' end, or just reasons. IO is a beta product and it's wise to expect one or two quirks from time to time
Charging worked flawlessly for the last couple of days, however, I no longer have the push notification with slot times through the Octopus App on iOS, I just figure the charge has started when I get the notification that the car started its charge from the Tesla app, then I go into Octopus to check the schedule. Minor inconvenience if at least it charges when it's supposed to...
Definitely odd. I have the same Hypervolt and am experiencing no issue. Would it be possible for you to be up and about at the start of one of the schedules and check the full 32A is being delivered in the Tesla app? Could probably be done with a basic quick plug and charge as well if you don't want to stay up to check it.
Also, next time you get a schedule, would you mind posting a screenshot of it here along with the current SoC% of your car?
Just to confirm, I do get the full 32A - I always have but double checked this by letting it run for a couple of minutes when I plugged in tonight.
I've plugged in with 70% SoC (which is higher than usual, I'm usually at 50-60% when plugging in), have given target SoC of 100%, and have been given the attached schedule. Again, it's given more than enough time so we'll see how well it charges. I'd expect it to stop start as it sees fit within this window no matter the SoC but still expect it to reach target.
I reckon it'll work tonight just because it only needs to charge 30% as opposed to my usual 50%ish.
Have any of you with this problem used a 10A granny charger at home at any point, even if just for one night? I had similar symptoms for a few weeks after charging the Tesla on a slow charger for a single night (our other EV occasionally needs a 7kW charge). What seems to happen in our case is that OI assumes we’ve switched to a 2.3kW charger, calculates how many kWh it can add at 2.3kW in the available time, and stops charging when it reaches that level even though we’re using a 7kW charger.
I haven't, I've only ever had the Hypervolt charger.
This morning a “We've lost control of your device - please reconnect through the Octopus app” email and no overnight charging from the looks of it.
Will see if 2023.12.1 resolves something that was broken. Had reconnected yesterday evening as it happens, seems to have made no difference.
Just switched to IO and got better rates than expected, fixed till next year!
I was expecting 42p peak and 10p off-peak.
I switched to IO yesterday just before my Go tariff ended. I thought I’d seen a message from Octopus that they couldn’t offer fixed term deals at the moment because of the rules about energy price caps so I don’t know how this was offered ! My new tariff is 10 p off peak but 45p peak. Fortunately, having just had batteries installed to mop up surplus solar, I’m using virtually no peak electricity at the moment. In the winter I will be able to top up the batteries off peak so should still neeed no peak electricity. The difference between the 10p and 45p rates should pay back the cost of the batteries in a reasonable period so long as the differential continues…
I switched to IO yesterday just before my Go tariff ended. I thought I’d seen a message from Octopus that they couldn’t offer fixed term deals at the moment because of the rules about energy price caps so I don’t know how this was offered ! My new tariff is 10 p off peak but 45p peak. Fortunately, having just had batteries installed to mop up surplus solar, I’m using virtually no peak electricity at the moment. In the winter I will be able to top up the batteries off peak so should still neeed no peak electricity. The difference between the 10p and 45p rates should pay back the cost of the batteries in a reasonable period so long as the differential continues…View attachment 930149
All the Octopus tariffs are “variable” so they benefit from the price cap. Rather than a guaranteed, fixed tariff for a year it may change, where you’ll be given a month’s notice. I’ve been on IO since December and our rate went up slightly this month.
I’ve just had an email off Octopus 🐙 stating from 21st Apr they’re dropping the rates again to 7.5p overnight and 7% decrease in day rate.
Well done Octopus for passing this along quickly.
Detail, if it helps anyone. Obviously the actual figures are specific to my region, but this is definitely good to see prices being dropped.
My initial comment was in response to Kelvin 660’s post #1755. I was surprised Octopus had offered a fixed IO rate until 13/4/24 for precisely that reason. Anyway, regardless of that, it’s good to see variable rates coming down.
Yes, the fixed rate mentioned by Kelvin is unusual.
Though, with the latest information about the drop in rates, I wonder whether Octopus are now happy to offer fixed rates, again? According to the email, they’re expecting rates to keep dropping, so maybe that’s why.
