Does the following make sense? What is your setting on that feature?
From the UM.
Headlights After Exit
When you stop driving and park Model S in low lighting conditions, the exterior lights automatically turn on. They automatically turn off after two minutes or when you lock Model S.
You can turn this feature on and off using the
touchscreen. Touch Controls > Settings >
Vehicle > Headlights After Exit.
Max, if you check your setting as Soolim pointed out, I can test with 6.2 for you.
In 6.2,
1. Open door, sit down, close door, press brake.
2. Headlights turn on
3. 17" indicates headlights on
4. Slide 17" to headlights off
5. Headlights turn off
6. 17" indicates headlights off
7. Open door, get out of car, instrument cluster goes to "Car Off"
8. 17" auto slides to Auto
9. Sit back in car and close door
10. "Car off" on IC, headlights are off, 17 indicates headlights off, slider is on Auto
11. Hit brakes, headlights turn on, 17" indicates headlights on.
12. Slide to Off and headlights turn off, 17" indicates headlights off.
In 6.2,
And I do have the headlights on after exit, do you?
I do NOT. I will retry with that turned on.
I do NOT. I will retry with that turned on...
Turning on "Headlight on after exit" makes v6.2 (2.5.71) behave the same way as Max outlines. Once I get off the seat, the slider automatically goes to Auto, the headlights turn on, and moving to "Off" doesn't do anything.
My thoughts = working as designed
The 17" having the lights on is "live status" of what the car is actually doing. The slider is what the car should do in normal circumstances. The "headlights after exit" overrides normal behavior and forces "On" when the car switches to "Car Off" for whatever period of time.
Fully agree with your thoughts = working as designed.
No need, but thanks.
I think this is still a bug due to the fact that when I do the experiment step-by-step as you outlined it, and turn the headlights to off AND then press the brake pedal, they go to auto. This should not happen regardless of the "Headlights on after exit" setting.
Is it possible that the software is, in this case, just using your pressing the brake pedal as the indicator that you are turning the car back on (even though you are not?) What I mean is, is the behavior you are seeing consistent with what would happen if you were to press the brake pedal and continue to then start the car?
What do you mean continue to start the car? I press the brake pedal, the car is started, no? Do you mean when I put it in gear?
That is what I meant, but in retrospect of course you are correct that the car is "on" with just the brake pedal pressed. It's one of those things I don't even really think about any more, and somehow when I was writing my response to you I was thinking starting the car was a two-step process--brake pedal, and engaging a gear.
Sorry to have added to the confusion.
Hi all,
Can't find this elsewhere using search, though I'm either going crazy or .77 has stopped the ability to lane change across a solid line. In WA state most of the HOV lanes have solid white line along their edge with the main freeway. I am sure* that I used the able to lane change into/out of the HOV lane using auto-steering previously. Is this new?
thanks, Mike
btw wiki states hand on steering wheel is required to initiate lane change for .77. Not for my tests... Others?
I didn't try it, I only stepped out to repeat the test Cyclone did. I'll add that to my list for tonight, heh.
For me, I leave my headlight slider in Auto and let the car takes care of lighting control including auto high beam. Headlights work for me perfectly.Turned off headlights after exit. On 17" turned headlights off. Car was off. Pressed brake, headlights turn to auto and turn on, put it in gear, they stayed on.
Tesla don't want you driving in the dark, that is why they planted a bug!:tongue:But on the one occasion I didn't want them to turn on, is when I discovered this bug.
