Cyclone
Cyclonic Member ((.oO))
Don't know if this was just a problem I was having, but under 7.1 when I initiated listen for a call, the UI would only bring up my address book and I had to select the contact to dial out. Under V8, making the command cause the dial out, or reading a phone number initiates the call. So I am finally where I was with my 2013 volt, four years later.
The automatic call out is only under two circumstances (both must be true):
1 - The speech recognition has high confidence (accurately or not) on which contact you said
2 - That contact only has one phone number in the contact details
If either of the above are untrue, you will get the popup. Personally, I would prefer the pop-up ALL THE TIME, and if I don't select something within X or Y seconds, the contact is automatically called if they have only one entry. I would also love an automatic call out (with the above X or Y second pause) if we could say "Mom Mobile" if you have a contact card called "Mom" and has "Mobile" and "Home" as entries under the contact details.
