Turns at stop signs were super smooth.
Hard not to be, it does it so slowly. I’ve noticed jerking of the wheel when it is uncertain though.
V12.3 slowed down super smooth.
I believe this on streets where it is traveling below 30mph.
As before, slowing from 50mph-60mph on a nice sleepy suburban residential arterial is where the issues start to arise. (With less smoothness.)
Leaving my residential subdivision, it creeped forward twice, very comfortably and then assertively made the left turn.
You should try to do the turn with someone right behind you. Assuming a turn onto a quiet road, if honking does not occur, they have the patience of a saint.
It can take literally 10 seconds to decide to make a turn when no traffic is present (I checked the tape). And that doesn’t include the SLOW roll up to the line. Did you notice it stopping a few feet back from the stop line (if present)?
Am I the only one on a 25mph street who just smoothly releases the accelerator completely, so that I come to a stop right at the line, with maximum allowed regen? I don’t think so.
My only complaint is that it has trouble staying at my set Max limit. I didn't bother testing auto Max, but I'm guessing it's always on, even if it's toggled off and you are setting it manually?
Both modes are completely borked. So in a way, yes, Auto Max is always on. The old mode simply allows you to set a cap on speed (you’d need it to be set 10mph or so below the limit for it to fairly reliably cap the speed below Auto Max desires, so use fixed offset of -10mph, set it to 35mph in a 45mph, 15mph in a 25mph zone, etc. Obviously this is not useful). If on v11 you set your speed offset 10% high or whatever, it will now reliably drive around 10-20% below the limit (variable).
Pressing accelerator will override for 10s of seconds or so (length of time dependent on many factors). Then it will decay back to turtle mode.
