Note all of this is speculation but my best guess on what’s happening based on everything I’ve seen and read about it:I don't think that's accurate yet. The visualizations are still powered by the older v11 perception stack, along with active safety features like auto emergency braking.
There will definitely still be C++ code in the system—but I suspect the heaviest computational demands by far would be the complex heuristic planning code of v11.I have no idea how much improvement there theoretically would be, but it seems pretty unlikely the C++ gets fully ripped out any time soon (for the use cases mentioned above, active safety and visualizations).
I think best advice would be that you only need to do it:Let’s talk about camera recalibration
When and how often should we do?
You can use the USB stick that came with the car. I’ve also had luck using a slim 1TB external portable HDD, although depending on how quickly or slowly it boots up you might get an error and have to unplug/replug it when you get into the car. (Not sure if that’s a bug or something that happens with particularly slow drives.) The rest of the requirements are in the manual but lots of different USB drives will do. Don’t go less than 64GB minimum. Since the system is recording video so often, if your drive is too small you’ll get a lot of read/write cycles, which can wear the drives out faster.Why’s the latest USB stick we should use to increase sentry recording space? I’ve seen so many opinions for durability and extreme temperatures
What size also?
Documented 300-400ms, see prior posts. Pretty definitive, high quality video evidence.I think Tesla said they’re running at around 50FPS and latency is somewhere on the order of around 20-75 ms I’d guess.
So you're telling me to go burn one... no problem. Once I finish my Crown and Ginger ... edit: just checked X, a bunch are getting it. Looks like the usual crowd. Haven't burned one yet.Teslascope shows 2024.15.5 / 12.4.1 is downloading for 2 vehicles on 2024.3.25 and 1 vehicle on 2024.14.7. TeslaFi shows 2 Model 3 and 1 Model Y downloading. Probably early access / those who still have video snapshot button.
I think Tesla said they’re running at around 50FPS and latency is somewhere on the order of around 20-75 ms I’d guess. That is more than sufficient for all driving tasks. We as humans sure as heck can’t react that fast to anything.
I noticed that mine wouldn't update today as well.Tried 3 times with every trick in the book including service autopilot check, cannot get software check to update from 2 days ago. That has never happened to me before. Will try again after my next refill.
Love the disclaimer:
I am not sure we, the users, are at any position to quantify the latency. Latency could be HW or SW or both. How would you identify what it is?Documented 300-400ms, see prior posts. Pretty definitive, high quality video evidence.
I knew this moment would come. Checking tmc at midnight, reading this, and sneaking out of bed to the garage to burn an update check.So you're telling me to go burn one... no problem. Once I finish my Crown and Ginger ... edit: just checked X, a bunch are getting it. Looks like the usual crowd. Haven't burned one yet.
A good example would be a stoplight turning from red to green.I am not sure we, the users, are at any position to quantify the latency. Latency could be HW or SW or both. How would you identify what it is?
I was just coming on to say this. I’m stuck on Jun 4 after trying every trick in the book.Tried 3 times with every trick in the book including service autopilot check, cannot get software check to update from 2 days ago. That has never happened to me before. Will try again after my next refill.
I get it. it'd require you to drive more than 5mph over the limit.Idk if I’ll have time to download the update in the morning before work, last time I did this the update took like 1 hr by the time the install was finished
