I painted the white paint on the red painters tape but I don't know it will work or not.I tried it with the blue painters tape and it didn't work. I went out and bought yellow tape and it started to work. This was the driveway though.
When you say "helped it with lane selection", do you mean disengaged and reengaged?My FSD also auto enabled without any confirmation. While playing with the scroll wheel can get annoying, speed limits are too arbitrary here, and also auto max wants to go too fast in residential areas so manual speed is still the better option.
I found playing around with FSD hard to resist, so I became a guinea pig once more and tried it out on some difficult intersections around here, some involving a place where two busy roads come together at a traffic light and where the no block zone is more than 100 feet long, and another part involving 3 narrow lanes with zero lane markings and no shoulders. The lanes should be there, but it’s end of winter.
The car actually handled it all very well, especially when I helped it with lane selection early on. I find it makes decisions and reacts to situations much later than an attentive driver would, so helping it out makes it work better. I would say it even drove better than a nervous or non local driver would have through this same area.
It has a long way to go still, but I can see some of the promise of robotaxi if they really drill in on a geographic zone, fix each regression and focus hard on safety and not crashing. Late decisions and bad lane selection don’t matter as much if a person is being chauffeured, as long as the thing doesn’t crash and as long as it doesn’t do illegal manoeuvres. It can apparently perform almost magically well in some crazy situations, so to see it flake out and fail so badly in other much simpler situations is flabbergasting. Still, Waymo is the proof that at least in theory, it should be possible. If the hardware can handle it is another question but I guess we’re in the process of finding that out!
V12 is definitely better than V11 but way less predictable which I don't like. Same route I took yesterday with zero disengagements has 4 today, including it jumping into a turn lane which has never happened before.
Seems to have a lot of trouble with lane selection, particularly when a lane splits into 2 (like a turn lane or a widening in the road.)V12 is definitely better than V11 but way less predictable which I don't like. Same route I took yesterday with zero disengagements has 4 today, including it jumping into a turn lane which has never happened before.
There have been reports of the visor blocking the camera in same cases. I'm guessing your visor was down going towards the sun?FSD gave me alert and disengaged itself with reason "Autopilot is disabled. System error. In cabin camera is blocked" or something like that on the toll freeway 73 to Newport Beach. 5 minutes later I was able to re-engage FSD. It happened after the car directly faced the big red sun for couple minutes, then faced the dark sky when the freeway direction changed. I was not sure that was the reason.
It will get more predictable with more training data.V12 is definitely better than V11 but way less predictable which I don't like. Same route I took yesterday with zero disengagements has 4 today, including it jumping into a turn lane which has never happened before.
Mostly no. I disengage when it’s about to do something I don’t like, or make the situation uncomfortable or cut someone off.When you say "helped it with lane selection", do you mean disengaged and reengaged?
I’ve noticed use of the accelerator causes nags to come much more frequently. Kind of like the system is checking if you are aware that FSD is still enabled. Might be possible to easily miss if you’re doing UPL, merges or anything else where you should NOT be looking at the screen.Drive better? Honestly 4 strikes in a month or less is clearly a user issue.
That's true if the driver doesn't to learn from the safety alerts on how to use the system.With V12 going out to the masses this will most likely become a common occurrence.
You don't need to navigate. If it's enabled just turn it on. You can joy ride and use turn signals to change lanes and turn at intersections.how do i do "mixed mode" 'SFSD and me'
I just want to joy ride around nowhere special, no destination, bopping down the highway and "lets turn left at this T real soon
Do I have to do a "navigate to ______"?
SFSD turns on if i flick the stalk going nowhere in particular, no destination
So I can essentially navigate by using just "chill mode" and turn signals and just "bop around the neighborhood", then "hit nav to home"You don't need to navigate. If it's enabled just turn it on. You can joy ride and use turn signals to change lanes and turn at intersections.
My need to nitpick: It's FSDS for Full Self-Driving (Supervised), not SFSD.
Yup, I did exactly that in my 2022 MSLR, USS, 2024.3.10, v12.3.3 yesterday.So I can essentially navigate by using just "chill mode" and turn signals and just "bop around the neighborhood", then "hit nav to home"
we have 400 miles of canals and lots of dead ends
thanks for response
Can you use turn signals to turn at intersections now? That wasn’t the case in past versions.You don't need to navigate. If it's enabled just turn it on. You can joy ride and use turn signals to change lanes and turn at intersections.
You can buy a new car.My 2023 MSLR is on 2024.8.4, has anyone with version received v12.3.x?
I have read that i cannot downgrade the version from 2024.8.4 to 2024.3.x to get FSDS. Is my only option to just wait?
