RudeDude
MY-LR-5, Blue ext/white int. 8/17/2022
Not sure when I'll have time to do it... but I might do it and try to document for you and the community. I'd like to know for sure what the slave is set to and tempted to play with upping the total shared amps. The cabling has been very safe temps so far whether I pull max with the Model-Y or max across both cars so I'm feeling good about my branch wiring.Hopefully someone is willing to document a re-commission of their units or new setup so we can have a little more clarity. I'll make sure to do it once I get another WC
By the way... I used a thing called a "split bolt" to build my junction box for this branch sharing. https://www.amazon.com/dp/B0B3LBGC8N?psc=1&ref=ppx_yo2ov_dt_b_product_details So, I've got one set of wires (L1, L2, G) coming into junction and then the two coming out for the two TWCs. In my electrical research I learned that there are not wire nuts rated for three strands of 6 awg copper and a split-bolt (a compression splice) is the right way. Then you have to wrap the bolt and exposed ends with enough electrical tape / rubber tape to provide required insulation for 240v.
