Got an early UMC from a friend with visible melted plastic between the connector and the 14-50 adapter. During charging the AMPs would drop to 20 and clearly was not safe to continue using it that way. By the way, here is a disclaimer: I shall not be held responsible for any damage to hardware or persons that may arise from following the post below. Use this post and the information herein at your own risk. What I describe here is a modifications to electrical and electronic device. Do not attempt to follow anything listed below unless you are competent to do so, as you could get a serious electric shock or even electrocution if you do not know what you are doing. If you are in any doubt about your ability to perform a certain task, then get someone else who is competent to do it for you. Make sure any item you are working on is powered off and unplugged from the mains before starting work. I repeat, use this post and the information herein at your own risk. Many thanks to MPT for his advice. Here is the patient... Instead of throwing it away, I decided to cut the melted connector away and replace it with a Camco 50 AMP replacement plug ($15 at Amazon). After having cut the connector off, you are presented with the following: 2 Red wires 2 Black wires 1 Green/Yellow wire 1 tiny purple or maroon wire 1 tiny blue wire The Red and the Black wires are the two hots and go on the two opposing blades while the green is the Ground and goes to the round prong. There is no Neutral in the UMC so the bottom blade does not get connected to anything. Now for the tiny wires; the blue is not needed but the purple/maroon wire is needed to signal the Amperage required. This is the table: (Courtesy of various TMC members) 40 amps - 9.08k ohms 24 amps - 33.16k ohms 16 amps - 75k ohms 12 amps - 140k ohms Since the gaps between steps are fairly large I figured that a 1ok ohms resistor would do and to be safe I looked for the highest wattage possible at Radio Shack and came up with this pack of 5 They all measured about 9.7k ohms so I picked the closest to the desired value of 9.08k ohms I simply twisted the resistor in line between Ground and the purple and wrap it with electrical tape but it would't be a bad idea to solder it. Once plugged in green light goes on (otherwise you'll get a red one) Charging well at 40 AMP 231V
Here is a great donor UMC on eBay for conversion to NEMA 14-50 US $175.00 ... no affiliation TESLA Mobile Connector UMC Charging Cable Model S X Charger | eBay
How timely! Last week my car started refusing to charge from my UMC and after reading this post I checked the plug end and it had the exact same issue with the adapter pins melting. This fix worked for me in 30 minutes incl cleanup. Thanks for posting it!
Nope but I'd expect Tesla would take exception to the J1772 plug I put on the other end so I could charge both our MS and Fiat 500e (until our M3 arrives). Interestingly we installed a HPWC a year ago so this UMC was only used for 30A charging of the Fiat for the past year and still overheated at the plug end.
Wow-isn't that just a replacement UMC ? I would think demand would be pretty high for these.maybe supply chain issues ?
As a product, it didn't make much sense to me. the HPWC wasn't much more, and not being able to change tips defeats the whole.. MOBILE part of it...
I'm adding this datapoint to every thread where I see this table - 32 amps - 20k ohms (measured from a Canadian 14-50 adapter)
