All current S/X batteries use the same 18650 cells with the same chemistry - 75, 90, and 100. The 100 uses different modules which pack more cells per module.
And you know that as a fact because? Have you torn down all the packs and compared the cells?
Are you sure about that? Elon Musk said it was for "upgraded packs" back in 2015:
I think at that time these were new cells being produced, and it was experimental "baby steps", and thus perhaps they were only going into the 90 packs, since there were no 100 packs at that time, and he said it was chemistry for the "upgraded packs".
I hate to throw fuel on the fire (since I don't even really see this as a fire) but I'm not convinced that Tesla stuck with silicone once it appeared the 90 packs were degrading faster than the old 85's. Also,
@JonMc from Tesla told us it affects less than 1% of customers so it seems pretty limited in scope. But this is all just pure speculation on my part.
I miss the old days when we could discuss interesting things like this here without dramatic replies equating to Tesla is the devil, or conversely, is a saint, since Tesla is neither. It's just a corporation that is run by humans -- so it's flawed, like the rest of us.
On the question of what cells the 75 kWh and 100 kWh packs are using...
There is a way to infer the chemistry of the cells using existing data, but this is not 100% reliable.
(1) We know the actual specified kWh capacities of Tesla packs, thanks to work from wk057:
Tesla, please stop making up specifications... | wk057's SkieNET...
And:
Pics and Info: Inside the Tesla 100kWh Battery Pack | wk057's SkieNET
wk057's data from packs relevant to my calculations are:
- 85/P85/85D/P85D - ~81.5 kWh total capacity, ~77.5 kWh usable
- 90D/P90D - ~85.8 kWh total capacity, 81.8 kWh usable
- Original 70 - ~71.2 kWh total capacity, 68.8 kWh usable
- 75/75D - 75 kWh total capacity, 72.6 kWh usable
- 100D - As for real capacity, the BMS reports usable capacity at a whopping 98.4 kWh. It also reports a 4 kWh unusable bottom charge, so that's 102.4 kWh total pack capacity!
(2) We know the number of cells per pack, again thanks to wk057's pack teardowns:
Tear down of 85 kWh Tesla battery pack shows it could actually only be a 81 kWh pack [Updated]
- Tesla’s “85” kWh pack consists of 16 modules of 444 cells for 7,104 total cells.
wk057 also observed that in the 100 kWh pack, there are 516 cells per module, 16 modules, and a total of 8256 cells.
(3) Calculations:
(3)(a): 90 kWh vs. 85 kWh
As far as I know, the 85 kWh and 90 kWh packs have the same number of cells. The difference in capacity is due to the chemistry inside the cells. So the difference in capacity per cell can be calculated by simply dividing the total capacity of the 90 kWh pack by the total capacity of the 85 kWh pack: 85.8 kWh / 81.5 kWh = 1.05276...
which means that the newer silicon additive cells have about 5.3% more capacity than the classic graphite-only cells.
(3)(b): 75 kWh vs. 70 kWh
The original 70 kWh battery (
NOT software locked model from May 2016) dates back to April of 2015. It most likely still uses the older chemistry, because the "experimental" 90 kWh pack with the new chemistry was not announced until July 2015. The 85 pack continued to be sold for awhile even after the 90 became available.
The ratio of nominal capacity between the 75 and 70 packs is 75 kWh / 71.2 kWh = 1.05337... which
implies that the newer pack has 5.33% more capacity per cell than the older pack. The ratio of the 90 to 85 pack is virtually the same as the ratio of the 75 to 70 pack.
CAVEAT: I do not know that the # of cells in the 70 pack is the same as the # of cells in the 75 pack.
(3)(c): 100 kWh vs. 90 kWh
The 100 pack has nominal capacity of 102.4 kWh divided among 8256 cells, or 0.012403 kWh/cell
The 90 pack has nominal capacity of 85.8 kWh divided among 7104 cells, or 0.012077 kWh/cell
The 85 pack has nominal capacity of 81.5 kWh divided among 7104 cells, or 0.01143 kWh/cell
We can see from these figures that the 100 pack derives its greater capacity from both higher # of cells, and greater energy density.
Conclusions:
I believe that there is a strong possibility that the 75 battery uses the same chemistry as the 90 battery, based on comparison of the ratio of energy stored between the 90 and 85, and the 75 and 70. Again, the unknown here whether the # of cells in the 75 pack is the same as the # of cells in the 70 pack.
I also believe that the 100 pack uses a slightly different chemistry than the 90 pack, because the energy density of 100 pack cells is higher than that of the 90 pack cells.
