gr8tdane24
39 psi cold seems to be the sweet spot for me.What tire pressure are you guys running? According to tiresize.com a 255/55R18 should be at 36 on the Model Y.
40PSI since its cold then will lower to 38 in the summer time.Whoa - I've just been running 41-42 PSI. I tried lower pressures once to see if it helped with ride quality. I didn't notice an improvement, so I went back up. I'm concerned going lower will ruin my already fuel economy. I love the fat tires with no hubcaps, but it kills your economy (along with my heavy foot).
21". Someone here told me it was the closest overall diameter. Plus, it looks cool on the screen.For those that run 255/55R18, what tire size do you choose on the in-car menu?
BRAID Winrace T (cast)
BRAID Forged UR4 (forge)
OZ Racing Rally gravel design (cast)
Can all be made in 18x9.0 5x114.3 ET+30mm, not sure about where to go to get the OZ one as most places carry some cookie cutter sizes.. still curious if 265/55R18 would fit or not
Check the load rating on the 18” OZs. Might want to reconsider.I'd like to get the OZ one in white... 18x8 +38mm like methods. How do I go on about custom ordering it? I see that tire rack carries +45mm. Would that fit?
I like the methods but I want it in bronze. Unfortunately only black ones are available in 18s.
Black Rhino Sandstorm is a good 18” option too. I think they look better than the Methods.Ah if that's the case then I guess methods it is.... hoping they would come out with a bronze version.
black rhino arches 18x8 +30 can be had in bronze too
not sure. depends on the wheel? only seen them on MY LRWould +30mm offset clear performance brakes?
I wonder how this compares to the MPP lift kit, I can only assume that the ride quality is better?
That seems like quite an aggressive lift with just springs, though Eibach has been doing these for decades in the opposite direction (lowering springs).I wonder how this compares to the MPP lift kit, I can only assume that the ride quality is better?
But, this isn't compatible with coilovers.... however, it is compatible with the MPP lift kit, right?
Where are we at at total lift for the two setups?
lift spring(1.7") + MPP lift kit(+1.75") = 3.45"
VS
MPP lift kit(+1.75") + MPP Comfort Adjustable Coilovers (+1") = 2.75"
Is that accurate? (assuming long range Model Y)
Took the car out to King of the Hammers in Johnson Valley, CA. I was the only Tesla that attended in a sea of Rivians .
OMG_Rivian was my travel partner. His Rivian is in a few of the photos.
Here is the event we went to: https://www.optimabatteries.com/exp...oE3f7VOtxFfNcEZ7fm5CBzKxpVjdxpHa0Y37BzHmM_dO8
View attachment 905924View attachment 905925View attachment 905926View attachment 905927View attachment 905929View attachment 905930View attachment 905928
