Just had my car steer around a bit of road debris for the first time. Nice!!! It didn't seem to be represented in the visualization.
This was on a neighborhood street, and the debris was toward the left side of my lane. The car smoothly arced its path to the right side of my lane to completely avoid it. No braking at all. Had my eyes been closed, I wouldn't have even noticed the car was doing it.
I was going to post this exact thing. Water main had popped. Crew had a square cutout of asphalt in the right lane, with dirt piled up. I was wishing my Wife was with me so she could take a picture of the FSD visualization for it. Showed a perfect square of "non-driveable space;" square bordered with a thick red line.
Have you guys experienced the lag in deceleration if you reduce the speed with the scroll wheel? I'll tell it to reduce speed and it takes forever to drop the speed. I noticed the same for reducing speed when it passes a lower speed limit sign example: there is an area that goes from 45 to 35 to 25 in a fairly short distance, I get into the 25 zone and im still doing 40.
I haven't experienced this at all. It reacts immediately and usually smoothly for me.
I've experienced the delayed deceleration, starting with the latest release, but it's situational. The highway stack still responds nicely to scroll wheel induced speed changes, whereas FSD Beta seems to take its own sweet time... sometimes.
So random. Good drive one day, and abysmal the next - same route, similar conditions. Doesn’t instill any confidence at all. Looking forward to seeing if 10.4 is any better, repeatability wise.
Yup. I've been repeatedly driving an area around me where FSD chooses... poorly. I'm planning on driving this area over and over again with each release, just to see if it really does help.
Going to work everyday, I come up on wabash ave and turn right on rose-hulman rd. The speed limit on wabash ave is 45 mph. The speed limit on rose-hulman st is 15 mph. When I am driving manually, it is very easy. I come to a complete stop at the intersection (there are traffic lights not shown in this pic) and then make a slow 90 degree right turn at about 8-10 mph when it is clear. There is a speed limit sign after the turn that clearly says 15 but FSD Beta reads it as 25 mph. Weird because it is a normal, plainly visible sign. If I manually change the TACC speed to 10 mph, it handles the rose-hulman st pretty well, even the tight bends. But it does not know to do that since it thinks the speed limit is 25 mph.
I really appreciate how you include pictures with your scenarios; it makes it so much easier to understand. Although it does make me feel lazy.
I will try different coming from a different direction. But I will point out that once you complete the turn, the front cameras will have a clear view of the speed limit sign. So the car should immediately slow after the turn as soon as the front cameras see the speed limit sign but it continues to drive past the speed limit sign at the same speed. I specifically noticed that the speed limit on the screen does not update after the car passes the speed limit sign.
I'm having this same problem with a certain set of speed limit signs that the highway stack won't recognize. And they're big honking signs out in the middle of nowhere. No clutter to obscure them, nada.
Ok so something I figured out last night and have tested a little that has made my experience with beta sooo much better. I force it through turns now, not every turn but if there are other cars around and it hesitates at all I push the accelerator, not tap it, I push it as if I was driving and the car has done great every single turn. It's almost like it has a confidence problem like someone jumping out of a plane or something and if you just shove it the cars is like oh *sugar* here we go I better just make this work, and it has every single time. It hardly ever even jerks the steering wheel at all. They are the smoothest, frustration free turns I have had. I used to disengage all the time, now I just force the car through the turn and its like magic. I am still very cautious if there are vehicles in the oncoming lane on the road I'm turning onto because I worry about it overshooting the turn or something since I am controlling the accelerator but so far its been magic. If I don't force it through turns it will sit there and jerk the wheel left and right over and over before it decides to go like someone at a thermostat going back and forth between 67.7 or 67.8 in the end it doesn't matter just set it and walk away. Just something I have learned and thought I would share for the other people who have said they disengage a lot at intersections (obviously since you are overriding the system and making it go make sure there isn't a reason its not going)
Edit: I should specify I don't live in a big city environment, more rural so this has been helpful at stop signs and rural roads turns. Large intersections with traffic lights don't seem to really be a problem.
That's great advice, but would like to add one word of caution...
When FSD is being timid with creep, there's a fine line between telling it "hey, creep a bit faster" and "Boss says it's ok to go, so let's go!" So if you're just telling it to creep a bit faster, BE CAREFUL that you don't inadvertently tell it to just go.
@diplomat33 If true, why don’t they give us this “view”? Would be very helpful, actually.
Exactly.
Even my brother's Ford truck does this... show's him a complete top down "bird's eye" view around his truck. Doesn't seem like it would be that hard to implement.
