lohma004
New Member
If one is worried about slipping off I would recommend a different method to lift your Model 3 or do some of the following three things: Bolt the hockey pucks to the jack stands allowing the head of the bolt to be a center pin for the lift point hole. For the All-in-One and/or open center jack stand use a bolt and nut through the center of the hockey puck to keep everything from sliding off. Drill a shallow hole and put a short bolt into the center of the hockey puck on the one for the rolling floor jack.
How I lowered my Model 3.
Raise both All-in-Ones and put the 2x8’s under the left rear tire
Lower the left rear All-in-One and remove it
Lower the right rear All-in-One
Lift the left rear with the floor jack and remove the 2x8’s and the front left jack stand
Lower the floor jack and remove it
Raise the right rear All-in-One and remove the right front jack stand
Raise the right front with the floor jack and remove the All-in-One
Lower floor jack and remove it
Post results on TMC (optional)
Sorry, no instructional pics. I think the only reason to do this is if you are planning major maintenance or modifications. If you feel you need pictures you may want to pay for an easier lifting method and for someone else to do the work. I think I will put my car on four jack stands maybe once a year at most so it will be a long time till I will be able to do a time lapse or take pictures.
Why didn't you lower the car the same way you raised it?
