Are there a lot of J1772 stations in Australia?
Nope. Of the ones that do exist, many are on private property or are at car dealerships.
That's why I think a J1772 to Mennekes is not as important as a mobile charger that can be plugged into any wall socket. Sure it takes a ridiculously long time to fully charge up, but it certainly gives a lot more flexibility and is also designed to get you home or to a place with a HPWC. Supposedly one will be out next year for Australia but who knows.
at last count it was like 140. there are more J1772 then mennekes there are only about 15 mennekes type 2 in the wild. if your desperate for a mobile connector you can get a type 1 to type 2 cable and a Holden volt EVSE for $450, which would give you 10amp charging single phase.
Interesting. 140 J1772's doesn't sound like much at all (probably because it isn't much at all) compared to the number of, say, Nissan Leaf's on the road in Australia, reportedly 400+. Many of those would be fleet so not 1 J1772 for every car on the road but I thought the number would be higher.
This is the cord I designed. It works great for trickle charging at 30A, although the flap on the j1772 inlet failed within a week.I found this from a company in Guangzhou:
SAE J1772 (Type 1) to IEC 62196-2(Type 2) Extension Cord 32A for EV Charging in Type 2 Connector Cable from EV Charging (EVSE) for Sale
Looking into whether or not it would work for a Tesla Model S (HK/AU/NZ/EU model obviously)
Any ideas on this?
Steve
Steve
Thanks. I think I will order one also.
Most of the chargepoint chargers around here are j1772.
They will be my emergency fuel can in case I cut things too close
Cool. Did you include the resistor to signal the cable capacity to the car?Mike_j and DITC, you might also compare price with the company that made the cable I had designed (earlier in the thread, with photo).
The 62196 standard used by the Tesla expects a resistor to signal the cable capacity to the car. Without it you could overload the adaptor by connecting say a 60A J1772 to your Tesla through it.Why would you need to add the resister ? the only cable that needed the resister are ones for the 2010 i-meiv which aren't compliant they just use a J1772 plug. no EVSE box.
Mike_j and DITC, you might also compare price with the company that made the cable I had designed (earlier in the thread, with photo). The contact is called Victoria and she is familiar with the cable. Mine was made before Steve's but has not been tested on a car because of delivery delay. I don't get car delivery until 15th Dec, but the cable has been lab tested here and seems OK. I will do a test charge with some experts after Christmas. I am in Sydney but the car delivery delay, imminent rollout of the SCs, and oncoming UMC mean I may not use it unless I eventually get down to eastern Victoria, and maybe never. However, if dual J1772 and Type 2 chargers appear, I wonder if in the situation where the type 2 is being used by another Tesla whether the J1772 might still be useful…..the charge times are significant.
Zhangjiagang Uchen Technical & Engine Co.,Ltd.
Suzhou Industrial Park Dostar technology Co., Ltd.
Tel: +86-512-62953825
Fax: +86-512-62531887
Email: [email protected]
SKYpe:kathereverbright
Website: http://uchen.en.alibaba.com
