Gasaraki
The car will usually run because the "alternator" is converting the main battery power to 12V, actively charging the 12V battery. If the 12V is completely dead where it won't even take an amount of charge, then I don't think you can drive the car.Much appreciate the counsel. But once jump-started, can the car run if the 12v battery is dead ?
If that is true, then all the electronics can run off the main battery pack, right?
If the 12v battery powers electronics, then wouldn't it be better to jerry-rig in a 7-9 AH $20 lead acid battery that could (?) provide enough amperage to start up the electronics and accept a charge from the mothercircuits ?
Or is it known that much amperage is required for the car to drive and start ok?
I'm confused. Is it that normally the 12v battery is powering a lot of stuff but in parallel with a converter off the main battery, making it necessary only before the system is fully started? In that case what's minimum capacity required to get the car booted up, and would a small 7-9 AH battery be enough to get going out on the road if the real 12v battery fails?
Where can I find out what exactly normally runs exclusively off the 12v battery? Is there a diagram anywhere?
Usually even a "dead" 12V will take a charge if you actively charge it, it just won't hold a charge.
