I charged at the Jindabyne NRMA charger on Tuesday (2-Nov) about lunchtime (2021 MiC Model 3 LR - same firmware as you 2021.36.5.5). Charged from 41-66% in 25 minutes on the charger nearer to the lake.The NRMA charger at Jindabyne continues to be problematic with my Model S.
CCS communication errors appear to be the main culprit in my case.
Do other Teslas have issues with those Tritium chargers?
The worst I've had was the Mittagong one stop requiring an unplug/reholster/plug in/restart cycle about 6 or 7 times in one charging session (this was back in early 2020 though).Do other Teslas have issues with those Tritium chargers?
That's what Plugshare says, which seems to have been accurate in all other respects.Assume both CCS2/CHAdeMO ?
Also only appears to be two parking spots based on those pictures, which is a bit of a waste with those new Tritium units.That's what Plugshare says, which seems to have been accurate in all other respects.
As @Chuq says, it appears that there's four parking spots, two on the near side and two on the far side (similar to the way the Mittagong unit can be accessed from either side).Also only appears to be two parking spots based on those pictures, which is a bit of a waste with those new Tritium units.
If someone ever drives a Nissan LEAF to Coonamble, I'd be rather surprised. Sure, some of the less-common variants have the range to get there from Dubbo, but last I heard, if you try to rapid charge a LEAF twice on the same day, it'll fall over, as their battery packs don't have a cooling system, they overheat when they're on a rapid charger, and they won't have had a chance to cool down yet.If that's the case then it doesn't make sense to start deploying dual-CCS2 units at this stage. If one unit is out of order then the end result is no functional Chademo connectors. Which could be a problem in a remote location such as Coonamble.
The photo seems to be of the back of the charging units, judging by the way the cables go (I can't see the plugs). So you can charge 4 cars there if the dual-plug is enabled. All the NRMA sites (at least the ones on well-travelled routes) need to be upgraded to this.I notice there are parking spaces on both sides of the units which could allow this in the future - it would be interesting to know if this was intentional when they were designing the site.
Three new "coming soon" sites added - Broken Hill, Wilcannia and Cobar!
