Hi All. Just sent Octopus an email re a SMETS2 meter, they tell me that they are only fitting SMETS1, is that true ?
So do you think that is a Tesla problem that they might fix?That's odd - I don't have that problem at all. It does like to max out export around those hours but only a small amount comes from the powerwall if the sun is shining (eg right now it solar is producing 3.8 house is consuming 0.4, powerwall discharging at 2.6, export is 6)
I have several months remaining on the old 8p/8p rate, and will then find out firsthand what the new rate offering is. My original plan when considering a Powerwall was to fill it overnight with off-peak rates. The TEP worked out better. Depending on what the next rates we are offered are, we may switch out of the TEP and revert to my original plan...Just in case those on the TEP haven't noticed, Octopus has issued new import/export rates of between 10 and 12p/kWh depending on region and a 22p/day standing charge. I cannot confirm but the 8p Tesla EV owners' rate appears to have disappeared.
Go and Go Faster peak rates have also increased by about 15% but offpeak remains unchanged.
Perhaps because our PV is only 3.5kW we have never faced this issue. But in our setup with our DNO imposed export limit at 3.6kW the Powerwall seems to regulate itself during the 4pm dump to the grid so that it ramps down to allow our PV system to always continue to generate, sun permitting.I only have one complaint. Tesla empty the PW between 4 and 6pm every day. They refill it in the morning. We have found in the summer that because the PW is discharging when the sun is still shining, the panels shut down so they do not exceed the export limit imposed by the DNO. We therefore have to increase energy usage in that period so that we still generate and use solar during that period. WE tend to charge the cars therefore after 4pm.
The system would be perfect if in the summer months you could get Tesla to delay the PW dump untilthe last 2 hours of the peak window.
I asked the same question in the solar panel thread a while back, I was told by some PW owners that it doesn't discharge the PW, i.e the PW software intervenes and charges EV from the grid. I guess it must either detect the EV or that the load ~7kw is larger than what the PW can discharge to?Just looking at whether to go onto the Tesla Energy Plan when my Solar and Powerwall are installed.
Searched in quite a few threads here and can’t find the answer this question (unless I am missing something)
Is there anything set up by Tesla so it doesn’t just empty the Powerwall when you plug your EV in to charge?
Assume it still makes sense to charge from the grid rather than take all the power from the battery?
As I understand it, you would have zero control over when the Powerwall charges or discharges, other than setting the standby reserve. It's no longer "your" battery; the grid becomes your battery due to net metering.Just looking at whether to go onto the Tesla Energy Plan when my Solar and Powerwall are installed.
You don't have direct control over the standby reserve either, but you can choose to have it set to 20% when you join the TEP.As I understand it, you would have zero control over when the Powerwall charges or discharges, other than setting the standby reserve. It's no longer "your" battery; the grid becomes your battery due to net metering.
In the first full year of operation my Powerwall was about 88% efficient, and presumably will gradually deteriorate further, so it is necessary to take account of round trip loss when doing calculations.Does it matter? I'm asking because I can't get my head around this ...
Battery fills from PV during the day. Fully charged, and that will (lets say) exactly run out tomorrow when the sun comes up. Happy days.
Overnight I charge my car - from the grid. I buy X units (and don't discharge the PowerWall)
With Tesla Energy Plan the battery discharges to charge the car (lets say), so I wind up buying X-Units to bridge between battery running out and the sun coming up.
Looks about-same to me?
I'm sure there is some, modest, inefficiency from charging car from battery, rather than grid, but other than that because the Import / Export rate is the same will I actually care? Is there a situation where I could be significantly worse off? (such that I would be better off buying Of Peak units at, say, 50% of Tesla rate, and day units at 300% of the Tesla Rate (and any export that I did make at a pittance)
That's interesting, how did you measure that? It seems in keeping with Tesla's claimed "90% road-trip efficiency".In the first full year of operation my Powerwall was about 88% efficient, and presumably will gradually deteriorate further, so it is necessary to take account of round trip loss when doing calculations.
