As far as I have seen, the fuse in question isn't intended to do that. (It has no way to detect a collision, and no way to be remotely triggered.)Clearly if the system that disconnects the high voltage battery in an accident is not working this is a safety issue.
Hi. I am helping a neighbor with this problem. They have a 2016 model X. My statement to them was that this is a safety issue and the NHTSA issues safety recalls all the time on cars and the manufacturer *must* contact the current owner and resolve the issue. Clearly if the system that disconnects the high voltage battery in an accident is not working this is a safety issue. Reputable car manufacturers take safety recalls very seriously so they do not get the "ford pinto" stink on them. Warranty does not matter, age of the car does not matter. The NHTSA is an amazing thing in the US and we would all thank Ralph Nader! BTW my neighbor also had a roof panel fly off the car while on the highway. Tesla said "we have never seen that before ever, it will take us a while to order the parts, very odd that this happened to you." When I researched the pyro fuse issue i found a TSB at the NHTSA and a safety recall for this exact problem. When a car comes in for service it is normal to check for all recalls and all TSB. This car was never recalled and glue which would have resolved this problem was never applied. NHTSA campaign number: 20V710. Tesla’s own number for this recall is SB-20-12-005. So beware that Tesla is *not* contacting customers about recall issues and trying to charge customers for repairs that should be safety recall. Everyone should visit the NHTSA and check for recalls because Tesla is not contacting people. carcomplaints.com is another resource i use frequently to gently convince the service manager that this is a recurring design defect that i should not pay for. Having data that everyone has this issue with the service manager / regional manager has paid for 3x transmissions and earned me "thank you thank you thank you" from friends and family.
How much is it out of warranty? I saw someone say around $275.Update…. I was originally charged for the PyroFuse repair in my 2017 Model X, and finally after several calls to the SC I received my refund. You have to be persistent - it should be covered under battery warranty.
Depends on the model. Some cars need to drop the HV battery so those cost more in labor.How much is it out of warranty? I saw someone say around $275.
2012 Model S I just sold had that error pop up for 10 min then go away. Happened right after I did factory reset so maybe nothing.Depends on the model. Some cars need to drop the HV battery so those cost more in labor.
A 2012 should not have the battery fuse, unless it has a newer battery or the initial fuse was replaced for some reason.2012 Model S I just sold had that error pop up for 10 min then go away. Happened right after I did factory reset so maybe nothing.
The battery might have been replaced in 2014 without them telling me. It was taken in for some issue and I noticed the part number was different on the battery.A 2012 should not have the battery fuse, unless it has a newer battery or the initial fuse was replaced for some reason.
I don’t know for sure, but I think the new battery fuse started in 2016 or so. Others here are much more educated on the topic.The battery might have been replaced in 2014 without them telling me. It was taken in for some issue and I noticed the part number was different on the battery.
I could have the year of replacement wrong. I definitely got a battery fuse error that stuck on the screen for 15 minutes.I don’t know for sure, but I think the new battery fuse started in 2016 or so. Others here are much more educated on the topic.
My 2017 Model X it cost $435 - which in turn was recently refunded by the SC that did it.How much is it out of warranty? I saw someone say around $275.
Just got the error. 2016.8 MX P90DL.
Interesting that it took this long, I have seen many newer cars mentioned here?
Same part number for mine. 2000A.Shouldn't it be 2300A for Ludicrous?
