Probably not your issue but kinda in the same area. I read this in the manual:
Note: If Model 3 is charging and detects
unexpected fluctuations in input power,
the charging current is automatically
reduced by 25%. For example, a 40 amp
current is reduced to 30 amps. This
automatic current reduction increases
robustness and safety in situations when
an external problem exists (for example, a
home wiring system, receptacle, adapter
or cord is unable to meet its rated current
capacity). As a precaution, when Model 3
automatically reduces current, it saves the
reduced current at the charging location.
Although you can manually increase it,
Tesla recommends charging at the lower
current until the underlying problem is
resolved and the charging location can
provide consistent power."
how do you actually check the list of locations and charge rate limits that the car has stored?
