I also spray this down the rear vent exits under the seats for good measure.Zero Odor spray down from the intake vent with the AC on. Works wonders.
Our 2022 Y had those large HEPA filters in the frunk and the small standard cabin filters in the pedestal. No odor but changed and foamed the cabin filters after 1st year.has this problem been fixed on MY?
If you like written:Thanks. I guess I need to do this. Does anyone have instructions on how to get the drunk out?
I've managed to eliminate the terrible smell for good!1 week update on the big bottle of 19oz Frost King + nozzle from Kool-it, it smells extremely fresh and clean, no hint of the stink at all and no scent to speak of, just clean air. The other foaming cleaners I used never smelled completely clean quite like this.
Looks like having a lot of foam directly spraying into the fins at a perpendicular angle did a good job cleaning.
Yeah this isn’t a solution. This sucks that you have to do thatI've managed to eliminate the terrible smell for good!
4 months update since I used a 19oz bottle of Frost King: bad smell came back after about 2 months of cleaning and changing filters, but I found a solution! Even though the car is supposed to run the fan with AC off after we get out, the smell remains terrible after short stops. What I do now is manually turn off AC 30 seconds before getting out of the car, and turn fan to 8-10 speed with recirculate off. This has completely eliminated the smell issue. I still use recirculate mode manually when I'm stuck in traffic, but as long as I remember to dry out the AC coils until the air blowing out isn't cold anymore, there's no smells.
Wish the car could do this properly automatically, I KNOW it's SUPPOSED to do this, but obviously, it doesn't work as well as what I do manually, because now the smell's gone.
TLDR: Before getting out of the car, run fan on max speed with AC off and recirculate off until air isn't cold anymore, smells gone!
Correct. Why a new car does not have this issue but car older than 6 months has this issue?Yeah this isn’t a solution. This sucks that you have to do that
If you must run recirculation, use the auto mode instead of manual recirculation. People have reported manual recirculation is the problem. If you turn off recirculation and turn on auto and let the system decide when to recirculate, it seems to not cause as much problems.Retarded honestly I like running recirc as I don’t want disgusting smoke smells trash chemicals from the outside
Yes there are plenty that use auto mode with the problem, but manual recirculation seems to cause it to happen rapidly, and some people have seen relief when they disabled that, so that clearly is a significant contributing factor and may be the primary factor in some cases (in those cases it may be that pushed things just over the line).I only use auto so those reports are just people that think they solved it until it happens again. I never use manual mode.
Yeah it’s honestly stupid… I used a different cleaner $10 bucks worked well but I basically missed the whole radiator it shot to the other side.Tesla could probably tweak the SW to automatically run the fan for 30min or whatever after the AC is turned off as a bandaid, hopefully the refreshes will address this issue. Kinda defeats the "lower maintenance" costs if you have to replace air filters every year and use a can of kool-it. That's just as much as an oil change.
The Klima foam cleaner is a large can with more than the compartment can hold and a multi directions tube that is thorough is filling the compartment.Yeah it’s honestly stupid… I used a different cleaner $10 bucks worked well but I basically missed the whole radiator it shot to the other side.
When I took the original filters out there were even leaves in there…..
But yeah majority of people do 1 oil change a year and paying Tesla mechanic to change them for you is basically the price of a high end oil change
Honestly only had funky AC smells in vehicles with 150K miles not brand new ones
If you don’t aim the tube correctly there is an opening and it will shoot out the other side to the driverThe Klima foam cleaner is a large can with more than the compartment can hold and a multi directions tube that is thorough is filling the compartment.
Did u read the bandaid fix people are suggesting? Turning off the AC but keeping airflow for the last couple minutes of your drive. I think the real issue is moisture/water coming in from the right below the wiperblades where the intake is. Its just a big hole that water can get through. There are products that sorta block it Amazon.com but will restrict a ton of airflow.I’m really at a loss at this point I replaced the filters about two months ago in my model Y and I cleaned the coils and the bad smell is back. I can’t keep buying new filters and coil cleaner every few months. Does anyone else have any recommendations or something that I can try?
but it will restrict airflow.
