Overall 32.2 is the best release I've used so far. Autopilot is smoother, summon works the first try most of the time now, fewer phone connection problems and in general just fewer issues then prior releases.
I'm not 100% convinced yet, but I've noticed that when approaching fork in a road, using blinker and gently tugging on the wheel in the direction you want to go at the split will allow this to happen without disabling autopilot.
I would be extremely surprised if the car responds to a gentle tug on the wheel except to let it know you have your hands on the wheel. It would be nice if it responds to the blinker. You might try approaching the same fork half a dozen times and signaling one way half the time and the other way half the time..
Mine *seems* to take a lane turn as input, based on the nag rate. It seems if I make a lot of lane changes without pressure on the wheel, I don't get the nag (because I don't want to be holding the wheel when it changes lanes!!!).
I have noticed that my Tesla app is now giving me notices when the app connects and disconnects. Has anyone else been getting these notifications too? I can't seem to dismiss them like all other charging notifications. Not sure what the real purpose is. When it's connected I did see that it allows you to open the frunk or trunk and uock the doors. I'm assuming this is so you don't have to open the app all the time?
2018.32.3 also only lists bug fixes.
The taillight display on the MCU is still broken, for those that care
I think that is the Andoid answer to a lack of a widget like iOS has.I have noticed that my Tesla app is now giving me notices when the app connects and disconnects. Has anyone else been getting these notifications too? I can't seem to dismiss them like all other charging notifications. Not sure what the real purpose is. When it's connected I did see that it allows you to open the frunk or trunk and uock the doors. I'm assuming this is so you don't have to open the app all the time?
I've noticed the same thing and today I saw that some are reporting a bug that came with 32.2 concerning the AC. Tesla is answering those that called about it, that it is a known issue and will be fixed in an upcoming update.Yes, I noticed that the temperature has to be turned down lower than before to achieve the same level of comfort. I don't precondition the car unless it's really hot inside (>110F) and has been in the sun. If the app says the interior is around 90F after setting around in partial shade, I'd expect the HVAC to be on a pretty high speed when I first get in the car to get it to cool quickly. However, when I get in the car with it set at 72F, the fan stays at a relatively low speed and it feels uncomfortable for a few minutes unless I change the set temp manually.
I noticed that the front seat fan speed is higher if the back seat vents are on and slower when it's off. Probably due to needing to push more air physically farther. If I keep the back seat vents on, the temperature tends to come down to a more comfortable level faster as a result, but then the trade off is that it gets colder than the temperature I've set and I have to turn the temp up.
With how difficult it is to work the HVAC controls when the car is moving, it's just the latest annoyance that should be easily fixable.
Do we all get the new computer, or only those who pay for FSD?
Obviously only those who paid for FSD. No need to replace the autopilot computer if it will not be used.
Keep in mind: This is _not_ regarding the MCU. The MCU (the computer with the big screen) will NOT be replaced. This is about the Autopilot computer, which is a separate computer. You can easily verify this. You can reboot the MCU (2 button reset) while driving on Autopilot, and autopilot will continue to work fine.
I'm waiting a little while before buying the fsd package. I heard those people will get the new computer when that comes out. Any idea when that would be?
But FSD is really just more and better autopilot features that the autopilot features we get with EAP.
I actually think that if they've added this behavior they'd document it in the release notes because some way to tell the car which fork to take would be a big thing. My experience (28.1, I have not done enough driving since getting 32.2) is that it will follow the lines if there are lines, it does not take turn-offs, at least when I'm not signaling, and is unpredictable if there are no lines. Maybe it tries to determine which is the major continuation.
Maybe, but I doubt that Tesla will replace the computers for those who only have EAP. it would be too costly.
