croman
Click the energy button, then click on trip. It'll show you how your expected energy usage between stops (if you're using the onboard nav to go from supercharger A to supercharger B, it'll show you with what SOC you'll arrive and if you're above/below target).
It's useful, but they added the destination SOC to the map, so I don't use it that much anymore. Basically, if you're speeding and you continue to see arrival SOC decreasing, you probably want to slow down.
The nav's calculations are way too conservative to be useful. For example, it always tells me I need to stop at Superchargers far more frequently than is necessary. By using the nav energy and math, I can easily calculate my actual energy use and my tolerance for dropping below 5% allows me to skip SCs and particularly those that are way off the beaten path (eating energy to get to them and after filling up, wasting that to get back to the road).
Its certainly easier to just trust the nav but I also disagree with some of its navigation choices (evtripplanner is nice but also can be off depending on altitude shifts (which is overestimates losses as long as you can avoid hitting the physical brake).
